receivetest not working on Android 4.2.2
Posted: Thu 23. Oct 2014, 12:16
Hello everybody,
my name is Benjamin and I'm currently working on my Bachelor thesis using your Peak PCAN-USB Interface. The bus is connected to my Windows 7 (64Bit) PC and a Texas Instruments AM335x Evaluation Module running Android version 4.2.2 (Kernel version 3.2.0). I have downloaded the SDK for the board from the TI-website and used the document "howto-pcan_for_Android.pdf", which can be found here in the forum, to cross-compile your driver and test programs.
I am using HTerm as the terminal on the Evaluation Module and PCAN-View on my Windows PC to send and receive messages. Both are connecting with 500kBit. While using "transmitest", everything works like a charm. I can also use echo to send messages without any problem at all. Every message can be seen in PCAN-View. My huge problem is the other way around. When sending messages using PCAN-View, "receivetest" does not show any data at all. I've already searched for a solution in the forum but was unable to find one, so I'd like to provide some data which is almost always asked for when problems occur. I hope that helps.
Product: 2x PEAK Pcan USB
Connected to: Windows 7 (64Bit) PC, Texas Instruments AM335X Evaluation Module running Android 4.2.2
Tools Used: HTerm, PCAN-View, transmitest, receivetest
PCAN driver version: 7.12
Loading the driver:
cat /proc/pcan
./receivetest -f=/dev/pcanusb0 (BEFORE sending CAN data from the PC)
./receivetest -f=/dev/pcanusb0 (AFTER sending CAN data from the PC)
ls -l /dev/ |grep pcan
Since we use Linux rarely over here and because this is my first contact with the CAN-bus, I don't know what to look for anymore. Any help would be greatly appreciated.
Kind regards,
Benjamin
Loading the driver:
insmod /data/media/0/Download/pcan.ko
pcan: Release_20140723_n (le)
pcan: driver config [mod] [usb]
pcan: new usb adapter with 1 CAN controller(s) detected
pcan: usb hardware revision = 28
pcan: usb device minor 32 found
usbcore: registered new interface driver pcan
pcan: major 247.
*------------- Release_20140723_n (7.12.0) Oct 13 2014 13:06:16 --------------
*------------------------------- [mod] [usb] --------------------------------
*--------------------- 1 interfaces @ major 247 found -----------------------
32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
receivetest: device node="/dev/pcanusb0"
Only standard frames are accepted, init with 500 kbit/sec.
receivetest: driver version = Release_20140723_n
^C
receivetest: type = usb
Serial Number = 0xffffffff
Device Number = 255
count of reads = 0
count of writes = 0
count of errors = 0
count of irqs = 0
last CAN status = 0x0020
last error = 0
open paths = 1
receivetest: finished (0).
^C
Device Number = 255
count of reads = 0
count of writes = 0
count of errors = 0
count of irqs = 0
last error = 0
open paths = 1
crwxrwxrwx root root 180, 32 2000-01-01 00:03 pcanusb0
Kind regards,
Benjamin
