Initializing COMs over PCAN_USB via Python 3.4
Posted: Mon 2. Feb 2015, 19:20
by capelzmann
Hello all,
I apologize for the simple nature of this question in advance. I am new to CAN and I am attempting something I am not currently skilled for so my powers of deduction are still under development.
I am attempting to initialize communications with my CAN network using the PCAN_USB channel via Python 3.4. Unfortunately I need 3.4 to run other control systems functions not available in Python 2.6. My secondary short term objectives are:
1. Simple Read Function
2. Simple Write Function
I've been using the PCANBasic.py and PCANBasicExample.pyw for guidance along with posts such as Pbreaction1: (
http://www.peak-system.com/forum/viewto ... ython#p957). Note I've attempted to update both PCANBasic and PCANBasicExample to 3.x via moderizie and manual replacement of functions with no luck regarding the Example.
Below is my current attempt to initialize communications, including the py file and the associated error when calling which is:
" AttributeError: 'c_ubyte' object has no attribute '_PCANBasic__m_dllBasic' "
How do I properly initialize communications?
Additional Notes:
System: Windows 7, 64-bit
Channel: PCAN_USBBUS1
Baud Rate: 500k
Hardware: PCAN USB
Successful Communications using PCAN-View and PCAN-MicroMod Configuration
Thank you sincerely in advance.
Re: Initializing COMs over PCAN_USB via Python 3.4
Posted: Tue 3. Feb 2015, 10:03
by K.Wagner
Hello capelzmann,
your
best start is using the Help file which is delivered within the PCAN-Basic package. There you will find minimalistic examples on each PCAN-Basic method, for example:
- PCAN-Basic Help Document
- Python_Help.jpg (128.87 KiB) Viewed 13262 times
capelzmann wrote:1. Simple Read Function
Search in the help document for the methods "Read" and "Write" and you will see a small example on these operations within Python, as shown above.
About your code:
- First of all, PCAN_NONEBUS is not intended to be used for communication.
- PCAN_NONEBUS is not allowed within Initialize at all.
- Initialize only received one parameter of type Handle. You are passing 2 in your code (PCAN_NONEBUS, and PCAN_USBBUS1)
I have installed Python 3.4 and used the Python shell to initialize the PCAN_USBBUS1 at 500Kb, to send a message, to receive one, and to uninitialize the channel again. See the picture bellow:
- Simple Initialize-Read/Write-Uninitialize example
- Python 3.4.jpg (192.08 KiB) Viewed 13262 times
Posted: Wed 4. Feb 2015, 00:00
by capelzmann
Keneth,
That is incredibly helpful. Thank you for your patience and effort.
Andy
Posted: Thu 5. Feb 2015, 02:44
by capelzmann
For the record and to help any other new CAN coder, here is my functional code. I can successfully read and write to my CAN network. Note that another error in my implementation resulted from installing the 64-bit PCANBasic.dll instead of the 32-bit version. I am running 32-bit Python 3.4 on a Windows 7 64-bit machine.
Thank you again Keneth for the help.
#PCANBus_COM_testMIN.py
#Communications test for CAN bus via Python -> USB -> CAN
#version 1.0
#Useful Shell Commands
#import sys
#import imp
#sys.path.append('''C:\Python34\Projects\ARM''')
#import PCANBus_COM_testMIN
#imp.reload(PCANBus_COM_testMIN)
#INITIALIZE
import sys
sys.path.append('''C:\Python34\Lib\site-packages\python_can-1.4-py3.4.egg\can\interfaces''')
from PCANBasic import * ## PCAN-Basic library import
channel = PCAN_USBBUS1
baud = PCAN_BAUD_500K
# The Plug & Play Channel (PCAN-USB) is initialized
objPCAN = PCANBasic()
result = objPCAN.Initialize(channel, baud)
if result != PCAN_ERROR_OK:
# An error occured, get a text describing the error and show it
print(result[1])
else:
print("PCAN-USBx was initialized")
# Check the status of the USB Channel
result = objPCAN.GetStatus(channel)
if result == PCAN_ERROR_BUSLIGHT:
print("PCAN-USB (Ch-x): Handling a BUS-LIGHT status...")
elif result == PCAN_ERROR_BUSHEAVY:
print("PCAN-USB (Ch-x): Handling a BUS-HEAVY status...")
elif result == PCAN_ERROR_BUSOFF:
print("PCAN-USB (Ch-x): Handling a BUS-OFF status...")
elif result == PCAN_ERROR_OK:
print("PCAN_USB (Ch-x): Status is OK")
else:
print(result[1])
# Set Message Filter
result = objPCAN.FilterMessages(channel, 0x100, 0x199, PCAN_MESSAGE_STANDARD)
print(result[1])
else:
print("Message Filter Applied Successfully")
# Read message from the USB Channel
n = 0
readResult = PCAN_ERROR_OK,
while(n < 1): #readResult[0] & PCAN_ERROR_QRCVEMPTY) != PCAN_ERROR_QRCVEMPTY:
# Check the receive queue for new message
readResult = objPCAN.Read(channel)
if readResult[0] == PCAN_ERROR_OK:
# Process the received message
print("A message was received")
print('[0]',readResult[0]) # A TPCANStatus error code
print('[1]',readResult[1]) # A TPCANMsg structure with the CAN message read
print('[2]',readResult[2]) # A TPCANTimestamp structure with the time when the message was read
msg = readResult[1] #readResult[1] TPCANMsg()
#print('msg = ',msg )
print('ID = ',msg.ID)
print('MSGTYPE = ',msg.MSGTYPE)
print('LEN = ',msg.LEN)
print('DATA[0] = ',msg.DATA[0])
print('DATA[1] = ',msg.DATA[1])
print('DATA[2] = ',msg.DATA[2])
print('DATA[3] = ',msg.DATA[3])
print('DATA[4] = ',msg.DATA[4])
print('DATA[5] = ',msg.DATA[5])
print('DATA[6] = ',msg.DATA[6])
print('DATA[7] = ',msg.DATA[7])
else:
result = objPCAN.GetErrorText(readResult[0])
print(result[1])
n = n + 1
n = 0
while(n < 1):
msg = TPCANMsg()
msg.ID = 0x209
msg.MSGTYPE = PCAN_MESSAGE_STANDARD
msg.LEN = 8
msg.DATA[0] = 0xFF
msg.DATA[1] = 0x00
msg.DATA[2] = 0x00
msg.DATA[3] = 0x00
msg.DATA[4] = 0x00
msg.DATA[5] = 0x00
msg.DATA[6] = 0x00
msg.DATA[7] = 0x00
result = objPCAN.Write(PCAN_USBBUS1,msg)
print(result)
else:
print("Message sent successfully")
n = n + 1
# All initialized channgels are released
objPCAN.Uninitialize(PCAN_NONEBUS)
Posted: Thu 5. Feb 2015, 13:24
Thanyk you for sharing your code!
Posted: Thu 10. Aug 2017, 10:00
by haseel
Dear capelzmann,
Thank you for sharing your code.
I am able to write the message over CAN BUS, but unable to use Read function.
Please find below the output .
The receive queue is empty
This means "objPCAN.Getstatus(Channel)" = PCAN_ERROR_OK
but "objPCAN.Read(Channel)" = The receive queue is empty
What could be the probable reason?? Any idea
Thanks in advance
Posted: Thu 10. Aug 2017, 10:26
PLEASE READ THE MANUAL
- you also have asked the same question in a other thread - please do not create support for nothing !
If you call the status function and get
it told you that tall is OK
if you call the read function and get
then the Receice Queu is empty - no CAN Frames on the BUS -- no messages in the queue!
