Receiving Messages and reading their data
jnota
Post by jnota » Tue 19. May 2015, 09:02
Hello everyone,
I started to use PCAN Explorer 5 a couple of months ago and right now I'm trying to create VBS Macros to test with some projects.
I've already written successfully some Macros to transmit CAN messages.
Now I wanted to check out if there are received messages from a certain CAN-ID and at last read their data.
I've already managed to check if there are some messages from that CAN-ID and to count them, but I can only read the data from the last one.
How can I read the data of all received messages from a CAN-ID?
Your help would be appreciated.
Thank you in advance!
Here is my code at the moment:
Function canerrors()
	Dim msgs, errors, cont, cont2, a, b
	Set msgs = Connections.ReceiveMessages
	cont = msgs.FindID(&H083).Count
	If cont = 0 Then
		MsgBox "There are no CAN errors!", vbOKOnly + vbInformation, "CAN Test"
		Exit Function
	Else
		Set errors = msgs.FindID(&H083).Item(1)
		cont2 = errors.EventCount
		MsgBox "There are some CAN errors!" & Chr(13) & "(" & cont2 & " errors)", vbOKOnly + vbExclamation, "CAN Test"
		With errors
			a = Hex(.Data(0))
			b = Hex(.ID)
		End With
		MsgBox a & "," & b
	End If
End Function
Re: Receiving Messages and reading their data
Post by PEAK-Support » Tue 19. May 2015, 09:54
We do not understand what exact you like to do. If you want to get all CAN-ID´s with ID 0x083 and print out the DataByte 0 , you need to do this in a loop for Online (live) capture.
If you like to get this info out of recived (in the past) CAN Messages, plrease use the Tracer function.
In the receive List you will only find the latest CAN Databytes of a received ID , and the counter how often the ID was received - no history Info of DataBytes from the past where stored.
jnota
Post by jnota » Tue 19. May 2015, 10:10
Hello U.Wilhelm,
Thank you for your quick answer.
At the moment what I'm trying to do is the following:
1) First I send some messages to the Bus.
2) At the end of the transmission, I want:
2a) To check if there are some received messages with a certain CAN-ID (e.g. 0x083) --> (I've already achieved that.)
2b) To count how many messages did I receive from that CAN-ID --> (I've also done that)
2c) And finally to read all data from that received messages. --> This is where I'm stuck at the moment.
Could you help me out?
Post by PEAK-Support » Tue 19. May 2015, 11:03
OK, you like to start your Macro , and want to send one spezific CAN ID.
After that you will wait for the specific answer (ID) and loop until...?!?
what is your end condition ?
Here a simple Macro which wait for specific Data
'FILE DESCRIPTION:RecvCAN Data
Sub RecvCANData()
'DESCRIPTION: Read CAN Data - see if in a defined CAN Msg data one Bit is set
  ' To view the output messages of this macro, open the Output Window and
  '  select the "Macro" tab
  Dim Myclient, MyConn
  Set MyClient = CreateObject("Pcan3.PCANClient")
  MyClient.Name = "RecvCANDataMacro"
  If Connections.Count > 0 And Connections(1).Protocol = peProtocolCAN Then
    ' Connect to the same Net that the first connection in the
    '  current project uses
    Dim obj
    Set obj = Connections(1).CommunicationObject
    MyClient.Device = obj.Parent.Device
    Set MyConn = MyClient.Connections.Add(obj.NetName)
  Else
    ' Connect to the default "TestNet"
    Set MyConn = MyClient.Connections.Add("TestNet")
  End IF
  If MyConn.IsConnected = False Then
	MsgBox "Cannot connect to Net"
	Exit Sub
  End If
  ' MyConn.RegisterMsg &H000, &H800, False, False
  ' MyConn.RegisterMsg &H00000000, &H1FFFFFFF, True, True
  ' MyConn.RegisterMsg &H600, &H1FFFFFFF, True, True
  PrintToOutputWindow "Start the Read...."
  i = 0
  Dim RcvMsg
  Set RcvMsg = MyClient.Messages.Add
  Do
  	Do While not RcvMsg.Read
	  ' Wait for a received message
	   Wait(10)	' Prevent 100% CPU load
    Loop
	If RcvMsg.LastError = pcanErrorOk Then
	 If RcvMsg.DLC > 0 Then ' Yes, >0 DLC ist OK
	  If RcvMsg.Data(0) AND &h80 Then
	  	PrintToOutputWindow "Received CAN ID: " & CStr(RcvMsg.ID)
	    PrintToOutputWindow "Data0 is set to 0x80"
	    i = i + 1
	   End If
	  End If
	End IF
  Loop While RcvMsg.ID <> &H001 ' Stop when receiving ID 0x001
  PrintToOutputWindow "Finished, " & CStr(i) & " messages 0x80 in Data0 received !"
End Sub
jnota
Post by jnota » Tue 19. May 2015, 11:26
I start the Macro with an InputBox asking user to select 1 of 2 possibilities and then another InputBox asks for how many times wants the user to repeat that process (variable 'cont').
Supposing the user chooses Option 1 and wants to repeat that for 10 times, the Macro will send 10 times a specific message, for example this:
For i = 1 to cont
       movement &HBE,&H01,&H1E,&H0A,msg
Next
Function movement(a,b,c,d, msg)
	Wait 250
	With msg
		.Connection = Connections(1)
		.ID = &H18B
		.DLC = 8
		.Data(0) = a
		.Data(1) = b
		.Data(2) = c
		.Data(3) = d
		.Write 0
	End With
End Function
After that test is complete, I want to see whether some messages from a certain CAN-ID (e.g. 0x083) were received or not during the transmission, how many times and what data had come with those messages?
So the stopping criteria is just the number of times the user wants to repeat the message sending.
Post by PEAK-Support » Tue 19. May 2015, 12:51
Hi, try this:
'FILE DESCRIPTION: Keine Beschreibung angegeben.
Sub SimpleProtocol()
  'DESCRIPTION: This MACRO send a request to a ECU and wait for n-Times for any answer from the Bus
  ' The User could use the Input Box to define the value of the retry counter
  ' To view the output messages of this macro, open the Output Window and select the "Macro" tab
  Dim UseConn, conn
  ' Find the first enabled connection in the project that uses the CAN protocol
  Set UseConn = Nothing
  For Each conn In Connections
    If conn.IsEnabled And conn.Protocol = peProtocolCAN Then
      Set UseConn = conn
      Exit For
    End If
  Next
  If UseConn Is Nothing Then
    MsgBox "This Project does not contain any enabled CAN connections!"
    MsgBox "Please check your Connection Box if your Hardware is connected."
    Exit Sub
  End If
  '  Create a new client and connect it to the same Net that the
  '  found connection uses
  Dim MyClient, PcanConn
  Set MyClient = CreateObject("PCAN3.PCANClient")
  MyClient.Name = "SimpleProtocol"
  MyClient.Device = UseConn.Device
  Set PcanConn = MyClient.Connections.Add(UseConn.CommunicationObject.NetName)
  ' Set Filter, so that we only receive in this script ID from 0x083 to 0x18B
  PcanConn.RegisterMsg &H083, &H18B, False, False
  ' i ist the counter how often we receive the ID 0x083
  i = 0
  ' count is the loop counter - changed by a input box value
  count = 0
  Dim RcvMsg 'we use this structure to Receive CAN Frames
  Dim SendMsg 'we use this structure to Transmit CAN Frames
  ' Now create and initialize a new transmit message
  Set SendMsg = MyClient.Messages.Add
  timestamp = MyClient.GetSystemTime
  PrintToOutputWindow "Macro running"
  strcount = InputBox("Loop Counter", "SimpleProtocol")
  If strcount <> "" Then
    count = CLng(strcount)
  Else
    count = 5
  End If
  ' Here we start!
  ' Now we add the needed DataBytes to the CAN Request Message
  ' For example Byte0=0x10 and DatByte1=0x11, ID=0x83, DLC = 2, STD CAN Frame (11Bit)
  With SendMsg
   	.ID = &H083
   	.DLC = 2
   	.MsgType = pcanMsgTypeStandard
    .Data(0) = &H10
    .Data(1) = &H11
  End With
  ' here we start the Loop! -- running until the conter reached the limit
  Do
    ' Send the defined CAN ID - also could be done in a SUB - thats up to you
	SendMsg.Write PcanConn, timestamp
	PrintToOutputWindow "CAN ID send"
    ' sleep 5 milisec. to give the CAN Bus a chance to transmit the ID and the ECU to answer :-)
    Wait(5)
	if RcvMsg.Read Then ' Read next CAN Date (keep in mind Filter is set!) from Queue
     ' check if CAN Frame received
      ' Check if ID = 0x083
      If RcvMsg.ID = &H083 Then
        ' print out text
      	PrintToOutputWindow "ID 0x083 Received !"
      	i = i + 1
      	' copy the received Databytes to the Output Window
      	for a=0 to RcvMsg.DLC
      		PrintToOutputWindow "Data" & CStr(a) & ": " & CStr(RcvMsg.Data(a))
      	next ' next a
      	' to stop the loop we set count now to 1 - so next decremt it will be 0
      	count = 0
      End If ' Endif ID OK
     End IF ' Endif no Error
    End If  ' Endif Read OK
   ' Loop until Message ID 0x101 receiced
   count = count -1
   Wait(250) ' here we wait 250ms until we try the next resend - without a delay at this point, all CAN Frames will be send within mSeconds
  Loop While count > 0
  PrintToOutputWindow "Finished, " & CStr(i) & " messages with ID 0x083 received !"
End Sub
jnota
Post by jnota » Tue 19. May 2015, 13:09
Thanks once again U.Wilhelm!
I'll try that and then I post here some feedback.
jnota
Post by jnota » Tue 19. May 2015, 16:12
Hi U.Wilhelm!
I've already tried your script and after some minor changes it has worked fine, just like I wanted! :)
Thank you very much for your precious support!
jnota
Post by jnota » Tue 19. May 2015, 16:47
Hi again,
Now I've noticed that sometimes the script doesn't "catch" all the errors, comparing to the Receive Window in PCAN Explorer. It seems like the messages are sent too fast for what the script can take...
Like I said, that doesn't happen always, just sometimes.
What can I do? Should I increase the wait time? I've already tried (I changed Wait (5) to Wait(10)) , but it doesn't work.
I have also a delay before every message's sending (250ms), immediately after the "Do" instruction.
Post by PEAK-Support » Tue 19. May 2015, 16:56
The queue will not miss any message, and the Client you have created with the script have it´s own queue. Simply open the PCAN-Status Panel while your macro is running - you will see a second client connected side by side to the PCAN-Explorer Send/Receive connection.
Does your external CAN node sending the specific ID (0x083) only once when you send out your request, or could it be that it send out more than once? The code i post read one answer from the receive queue if you send a request. (Ping/Pong) You need to extend the read function inside the loop in that way, that it reads until there is no other answer in the queue.
