Problem with PCAN-USB
USB to CAN Interface
satelitko
Post by satelitko » Mon 28. Sep 2015, 23:40
I bought PCAN-USB (IPEH-002021-138071) about a year ago and It worked without any problem (I use it maybe twice a week).
Today I noticed, that the red LED is on, when sending data it blinks, but it does not connect to the hardware.
I tried another interface (IPEH-002021-57300) and It works OK.
I measured voltages on DB-9, both pins have 2.5V to GND.
What can be the problem?
Regards, Gregor
Re: Problem with PCAN-USB
Post by M.Maidhof » Tue 29. Sep 2015, 16:03
all looks ok. You can do a short test by connecting two PCAN-USBs on the same PC and connect them on CAN with a terminated CAN cable. Than start two instances of PCAN-View with the same baudrate and send some data (cyclic messages with 10 ms). You should receive the data from the other module in the receive window of PCAN-View.
satelitko
Post by satelitko » Wed 30. Sep 2015, 07:38
Post by M.Maidhof » Thu 1. Oct 2015, 09:46
what does that mean?
satelitko
Post by satelitko » Mon 5. Oct 2015, 07:41
I replaced CAN transceiver (put in a TJA1040 which was on my stock). Now everything is OK and I am happy again ;-)
