PCANView has the nice function to show all available hardware interfaces in the connection window.
I'd like to have something similar for my own applications using CanApi2 (we have version 2.56.2). Is this possible and if yes, how?
André Hartmann
Scanning available CAN hardware / channels
- pcanview.png (48.89 KiB) Viewed 3202 times
Re: Scanning available CAN hardware / channels
you can use a for loop to scan for valid hardware handles on each driver:
Change the active device with SetDeviceName, to search other device drivers too (PCI, USB, ISA, DNG etc.).
Please have a look into the canapi2 help file, to get more information how to use those APIs
for(i=0;i<=MAX_HCANHW;i++)
ret=CAN_GetHwParam(i,CAN_PARAM_NAME,buff,sizeof(buff));
if (ret==CAN_ERR_OK)
// Hardware found on hardwarehandle i
// use handle i to get more details of the hardware by CAN_GetHwParam
Hi Michael,
thanks a lot for this information.
It allowed me to build a simple example, nothing fancy but working.
Only one note/question: the header file says, only Hardware 1...MAX_HCANHW permitted, so I guess the loop should run from 1?
Anyway, thanks for your fast help.
André
for (int i = 1; i <= MAX_HCANHW; i++) {
André
- own_scan.png (28.41 KiB) Viewed 3194 times
"0" is equal to an internal hardware, when the pcan-network is not linked to a real PCAN hardware. That is why a hardware handle of 0 is still possible in the canapi2. But you are right, in that context you can start with 1, because 0 will always return ILLHW.
