PPCAN - MIO How to set up 5V output channel 70h
Piotr
Post by Piotr » Wed 9. Mar 2016, 15:30
As in the topic. I am using PPCAN-MIO and I want to run 5V power supply. Is there any tutorial or sample how configuration and set up should looks like? I tried is several ways.
Thanks in advance,
Piotr
M.Gerber
Design & Documentation
Re: PPCAN - MIO How to set up 5V output channel 70h
Post by M.Gerber » Wed 9. Mar 2016, 16:56
Hi Piotr,
To permanently enable the 5-Volts supply at connector A8, you could set up the output on the Default value for data objects tab in the module configuration (default name: Config0). Use the Default Value 1 to enable the output.
There is a tutorial document on the supplied DVD (link to online files) under Tools > PCAN-MIO > Tutorial.
Hope this helps.
Greetings
Mark
Piotr
Post by Piotr » Wed 9. Mar 2016, 17:23
Thanks a lot. It works prfect!!
