Gateway in company LAN
Posted: Wed 30. Mar 2016, 16:05
by Hoern
i will use the Ethernet Gateway DR in our company LAN and therefore o have an problem.
The Ethernet Gateway DR has an defined IP address.
The gateway doesn't get access to our local LAN.
When i plug the patch cable out and in the switch doesn't recognize the device. Only when a power cycles of the gateway happend the switch recognize the gateway and show his MAC address.
Is there an Solution for this Problem?
Greets
Jannis
Re: Gateway in company LAN
Posted: Thu 31. Mar 2016, 09:08
by Hoern
So the Problem is solved, i must add default routes and activate them so the device sends automatic Ethernet packages.
