Signal-noise visible on Scope?
Handheld CAN Bus Diagnostics Unit - Version 2
Tesmec
Post by Tesmec » Sat 14. May 2016, 21:29
I did capture the CAN signal with the Scope and found strange noise affecting the bus, could you help me understand which could be the reason?
Thanks.
CAN signal.PNG (46.13 KiB) Viewed 4886 times
G.Bohlen
Hardware Development
Re: CAN signal
Post by G.Bohlen » Tue 17. May 2016, 09:39
this curve look quite good to me. There is a symmetrical overshoot when the bus changes from recessive to dominant, and it takes a little while until the signal settles when changing from dominant to recessive.
But the disturbance is far away from disturbing the signal. Detection level of a dominant signal is typically >0.7V (min. >0.5V) for the differential receiver voltage.
Gunnar Bohlen
