FMS Simulator 2 does not send Driver ID frame
Windows Software for Simulating CAN Data According to FMS Standard
fhardy
Post by fhardy » Thu 30. Jun 2016, 11:59
I don't manage to simulate the FMS Driver ID Frame (0x00FE6B).
I can simulate the tachograph frame with the tachograph tab, and change the Driver ID field, but the tool is not sending the Driver ID Frame.
How can I simulate this frame ?
F. Hardy
M.Riedl
Re: FMS Simulator 2 does not send Driver ID frame
Post by M.Riedl » Thu 30. Jun 2016, 14:13
Which kind of standard do you use in the software?
Do you have activate the PGN 0xFE6B Driver's Identification: ID in the Options dialog window?
Do you have activate the checkbox Card Present on the Tachograph tab for the Driver that should send the Driver ID?
There is a dependence between Card Present and Driver ID.
Please make sure that you use at least FMS 02.00/Bus-FMS 00.02 or later in the software and make sure that you activate the Card Present checkbox for the Driver you will use.
M.Riedl
fhardy
Post by fhardy » Fri 1. Jul 2016, 09:26
Yes I configured the software for driver ID:
But there is no frame FE6B genereted by the tool.
Post by PEAK-Support » Fri 1. Jul 2016, 11:01
Have you checked?
fhardy
Post by fhardy » Fri 1. Jul 2016, 15:36
Yes I have checked the FMS Version, and I tried with FMS 02.00 and Bus-FMS 00.02. Still no frame FE6B.
You mean Driver ID is not compatible with FMS 03.00 ?
Post by PEAK-Support » Fri 1. Jul 2016, 16:46
Belive us - it works - looks like you have not configured the Tool correct...
Please keep in mind - we talking about the ID 0x18FE6B00 !!
The PGN is 0xFE6B - this is a differnet - see options dialog Identifiert / Prio / Source Adress
Check if:
- you use the correct FMS standart (see main menu)
- you have select the PGN in the Option menu
- you set the card in the Simulation menu to "Card Present"
fhardy
Post by fhardy » Fri 1. Jul 2016, 17:19
Yes I am talking about the ID 0x18FE6B00.
I configured the tools as you recommended (you can see in the picture I posted).
I run more tests:
- when the checkbox "Card Present" is unchecked,I receive the driver ID frame (*FE6B*) (and its value is 2A 2A FF FF FF FF FF FF)
- when the checkbox "Card Present" is checked, I don't received the frame.
Post by PEAK-Support » Mon 4. Jul 2016, 08:33
I could not replicate your problem...
please check if you use the latest Version and the FMS 3.0 Standard.
We will forward the support ticket to our developers to take a closer look at the problem...
nbussac
Post by nbussac » Mon 4. Jul 2016, 15:55
I'm working with fhardy
FMS simulator.png (242.22 KiB) Viewed 18637 times
We've got the 2.6.0 trial version and we've got this in the log file :
;   Start time: 04/07/2016 15:40:06
;   PCAN-Net:
;   Columns description:
;   +-Message Number
;   |         +Time offset (ms)
;   |         |        +Type
;   |         |        |        +ID (hex)
;   |         |        |        |     +Data Length Code
;   |         |        |        |     |   +Data bytes (hex)
     1)         0.0  Rx     18FE6B00  8  2A 2A FF FF FF FF FF FF Card Present not checked
     2)     10000.0  Rx     18ECFF00  8  20 15 00 03 FF 6B FE 00 Card Present checked
     3)     10050.0  Rx     18EBFF00  8  01 44 45 20 31 32 33 31
     4)     10100.0  Rx     18EBFF00  8  02 20 20 20 20 20 20 20
     5)     10150.0  Rx     18EBFF00  8  03 20 20 20 20 20 2A 2A
     6)     20000.0  Rx     18ECFF00  8  20 15 00 03 FF 6B FE 00
     7)     20050.0  Rx     18EBFF00  8  01 44 45 20 31 32 33 31
     8)     20100.0  Rx     18EBFF00  8  02 20 20 20 20 20 20 20
     9)     20150.0  Rx     18EBFF00  8  03 20 20 20 20 20 2A 2A
    10)     30000.0  Rx     18FE6B00  8  2A 2A FF FF FF FF FF FF Card Present not checked
    11)     40000.0  Rx     18FE6B00  8  2A 2A FF FF FF FF FF FF
(Insert by PEAK-System)
Here the Trace with the marked Info:
Reason: Reformatted the log for better readability.
M.Riedl
Post by M.Riedl » Tue 5. Jul 2016, 12:09
If I understand, you miss the PGN 0xFE6B (CAN ID 0x18FE6B00) when the Card Present is checked.
If the Card Present of at least one Driver is checked, the Driver ID data will send with a Boadcast Announce Message (BAM). See CAN ID 0x18ECFF00 (TP.CM) and 0x18EBFF00 (TP.DT).
In both situations (Card Present checked and Card Present not checked) the data will send every 10 seconds only.
M.Riedl
