peak-linux-driver-8.2 chardev not working on 64 bit
Posted: Tue 24. Jan 2017, 16:00
Hey,
I installed the peak-linux-driver-8.2 on Ubuntu. CAN connection is via PCI card. After a reboot reading from CAN works sometimes for a short time. The output of cat /proc/pcan looks like this, when its not working anymore
cat /dev/pcan0 receives no messages
EDIT:I almost forgot: Same hardware configuration works on Ubuntu 32bit flawlessly. That means the hardware part seems to be correct.
Hope you can help me and thanks!
cat /proc/pcan
*------------- Release_20161108_n (8.2.0) Dec 2 2016 14:24:50 --------------
*--------------------- 2 interfaces @ major 244 found -----------------------
0 pci -NA- f9ce0000 016 0x011c 00000000 00000000 00000001 00000004 0x0002
1 pci -NA- f9ce0400 016 0x001c 00000000 00000000 00000000 00000001 0x0002
