My hard drive is filling up with messages from peak pcan - var/log/syslog & kernel are 60-70gb and I have to delete them occassionally. They don't indicate any error, it just looks like status or "what" is happening like sending and recieving. Can I shut this off? Why is this happening? Is there really a problem pcan 7 driver, ubuntu 14.0
Ton of these in syslog:
Apr 26 16:54:49 Perception kernel: [ 122.786708] pcan: pcan_usbfd_decode_canmsg(): rx=[flags=0x00 len=0x08 ts32=0x0742ee39 id=0x0000052f]
Don't have a sample of kernel log, but it's spammed too.
M
How to stop logging?
Re: How to stop logging?
please send the output of cat /proc/pcan to see which driver version you use at the moment.
When using an older driver 7.x, please update to version 8.x:
http://www.peak-system.com/fileadmin/me ... 3.1.tar.gz
Has this issue been resolved?
https://www.peak-system.com/forum/viewt ... slog#p4922 suggest turning off ACPI in BIOS.
I have the same issue and while rotating logs is one solution, it's not a definite solution. I tried upgrading the driver but my 3rd party application does not work with new driver so I'm sticking with 7.15.2 on Ubuntu 16.04.
*------------- Release_20150729_n (7.15.2) Mar 9 2016 13:02:06 --------------
*--------------------- 4 interfaces @ major 241 found -----------------------
32 usbpfd -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
33 usbpfd -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
34 usbpfd -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
35 usbpfd -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
to prevent those syslog messages with driver 7.15.2, please edit pcan_usbfd.c line 742:
to: #ifdef DEBUG
rebuild and reload the driver again, and those messages will no longer occure.
to: #ifdef DEBUG
