Linux Error Codes
Posted: Tue 18. Jul 2017, 00:07
by Cata1yst
Im trying to run PEAK within a virtualbox vm. Linux doesnt seem to work while windows works fine.
No compilation errors.
Dmesg output
[ 36.031736] usb 2-1: USB disconnect, device number 2
[ 43.599987] usb 2-1: new full-speed USB device number 3 using ohci-pci
[ 43.876447] usb 2-1: New USB device found, idVendor=0c72, idProduct=000c
[ 43.876452] usb 2-1: New USB device strings: Mfr=10, Product=4, SerialNumber=0
[ 43.876455] usb 2-1: Product: PCAN-USB
[ 43.876456] usb 2-1: Manufacturer: PEAK-System Technik GmbH
[ 43.888088] pcan: unhandled read data stream turned off (err -84)
[ 43.888438] pcan: error -84 submitting command
[ 43.889281] pcan: PCAN-USB channel device number=255
[ 43.889283] pcan: usb device minor 32 found
cat /proc/pcan
*------------- Release_20170613_n (8.4.0) Jul 17 2017 19:11:01 --------------
*---------------------------- [mod] [par] [usb] -----------------------------
*--------------------- 1 interfaces @ major 251 found -----------------------
32 usb -NA- dead00 000 0x001c 00000000 00000000 00000000 00000000 0x0000
Trying to write to /dev/pcan32
ls -l /dev/pcan*
lrwxrwxrwx 1 root root 9 Jul 17 22:03 /dev/pcan32 -> pcanusb32
crw-rw-rw- 1 root root 251, 32 Jul 17 22:03 /dev/pcanusb32
/dev/pcan-usb:
total 0
lrwxrwxrwx 1 root root 15 Jul 17 22:03 can0 -> ../../pcanusb32
echo 'm s 0x105 1 04' > /dev/pcan32
-bash: /dev/pcan32: No such device
Re: Linux Error Codes
Posted: Tue 18. Jul 2017, 08:11
We do not officially support VM systems - could work - must not - sorry!
Posted: Tue 18. Jul 2017, 19:09
by Cata1yst
Any ideas for me to look into at the least?
I'm really not sure why it works in a windows vm but not a linux vm.
Posted: Tue 18. Jul 2017, 19:14
it is depending on the used VM - some version work, others not, this vary from version to version - sorry - we can not help...try a differnt system - virtuell box mostly works (but also not all versions)
