AOUT value
olivierk
AOUT value
Post by olivierk » Wed 10. Jan 2018, 10:49
Does someone know if it is possible on PCAN-MIO with PPCAN-Editor to read a value from AIN, make some calculations and based on the result set the value of AOUT?
Thanks.
Olivier
G.Bohlen
Hardware Development
Re: AOUT value
Post by G.Bohlen » Wed 10. Jan 2018, 11:49
Hello Olivier,
yes, this is possible.
In the PPCAN-Editor2 you can go to the configuration-window, select tab "Function Blocks" and add a new Record.
Look at the document "Help/PPCAN-Editor_References" for all available function blocks.
Now you can select a Function code, e.g. Scaling. (output=input1*scale+offset)
Next you select the input1 of the function. To select Pin AIN0, you select
Input 1:
I/O Function="AIn level (90h)"
I/O Number="AIn0"
Input 2:
unused because Scaling block has 1 input and 1 output.
Output
I/O Function="AOut Level"
I/O Number=AOut 0"
Parameters:
Here you select scale and offset for the desired calculation.
output=input*scale + offset
Cycle time: choose how often this calculation should be done e.g. every 10ms
You can also do calculation in several steps. The intermediate result can be stored in a 32bit variable.
Choose a 32bit variable as output of a function block and input of the following function block.
(I/O Function: 32bit Variable, I/O NUmber 0..255)
If several steps are used, set the cycle time to the same value for all these steps.
Gunnar Bohlen
