Instruments panel switch
tguetle
Post by tguetle » Fri 10. Feb 2012, 11:09
i have a question about the Pcan Instruments panel. i have a rocker switch on a scene and this switch is connected to a signal in a symbol. So everything is fine.
But if i pressed the button, allways two can messages will be sended. I think, the first is sended if i pressed the mouse button and the second if i released the button.
Is it possible to configure this? can i switch off the sending on changes?
Re: Instruments panel switch
Post by M.Maidhof » Fri 10. Feb 2012, 13:13
which version of PCAN-Explorer 5 do you use at the moment? There was a bug in an older version of the Instruments panel regarding the rockerswitch and the transmitting of messages, please see history for more details:
http://www.peak-system.com/Instruments- ... 118.0.html
