Using 4 PCAN-miniPCIe at the same time
CAN-Interface for PCI Express Mini
Saike
Post by Saike » Fri 2. Feb 2018, 09:46
Now I use 4 PCAN-miniPCIe in one PC.
I cant know which connector is the PCAN0.
I found sometimes the serial name will be changed when I restart the PC.
How can I know which one is the PCAN0? How can I fix its serial name?
Thank you very much for your help.
Re: Using 4 PCAN-miniPCIe at the same time
Post by M.Maidhof » Fri 2. Feb 2018, 10:32
which OS do you use? Windows or Linux?
Saike
Post by Saike » Wed 21. Feb 2018, 03:44
I am using ubuntu 14.04.
Post by M.Maidhof » Wed 21. Feb 2018, 10:12
do you use the kernel driver for SocketCAN or the peak-linux-driver? If you use the peak driver, please post the output of cat /proc/pcan.
Saike
Post by Saike » Fri 23. Feb 2018, 08:37
I am using the peak driver.
In this PC, I installed a 4 Channels PCAN-PCIe and 2PCAN-miniPCIe.
In the First Picture, I cant read 4 Channels PCN-PCIe.
[img]/home/common/Desktop/1802144505.jpg[/img]
The Second Picture is after I restart PC.
[img]/home/common/Desktop/54302421.jpg[/img]
after I restart PC
after I restart PC
Post by M.Maidhof » Fri 23. Feb 2018, 09:52
as a first step, please update to driver 8.5.1
