Connect more than 10 PCAN-USB adapter to communicat over UDS
Posted: Mon 9. Apr 2018, 14:30
by Oprogramer
i am trying to connect more than 10 PCAN-USB adapters for UDS communication. I have read that it is possible to create and connect to 16 PCAN-USB interfaces with interface channels from PCAN-USBBUS1 - PCAN-USBBUS16.
But I have to create and connect to more than 10 PCAN-USB adapters over UDS and i only found 9 channels for UDS-Communication from PUDS_USBBUS1 to PUDS_USBBUS9.
Is there any why to connect to more than 10 PCAN-USB adapters for UDS communication?
Best regards
Re: Connect more than 10 PCAN-USB adapter to communicat over
Posted: Mon 9. Apr 2018, 15:01
by K.Wagner
PCAN-UDS can handle as many channels as PCAN-Basic (underlying transport layer API). The latest version of these APIs allow up to 16 USB channels simultaneously. If you cannot use more than 9 channels at a time is possible because your system has no resources enough to support more than 9 USB devices at a time.
Please check that:
- All PCAN-USB devices attached to your computer have the power LED on
- All PCAN-USB devices attached to your computer are also listed in the Windows device manager, i.e. within the node "CAN-Hardware"
- Neither any of the CAN-Hardware entries nor the USB controllers (Windows device manager, node USB-Controllers) are showing any warning.
Note: I have just tested with 2 PCAN-USB X6 devices (12 channels in total) and I could connect all of them.
Posted: Mon 9. Apr 2018, 15:35
by Oprogramer
Thank you for the fast answer. I have the older PCAN-UDS Api version where just 9 Channels could be used.
I will download and install the new PCAN-UDS Api version.
Thank you for the information!
Best regards
Posted: Mon 9. Apr 2018, 15:40
by K.Wagner
Please note that older versions of PCAN-UDS/PCAN-Basic could handle up to eight (8) channels; new versions up to sixteen (16). But there was never a version handling 9 channels!
Posted: Tue 17. Apr 2018, 12:30
by Oprogramer
Hello again,
I checked the serial numbers of my PCAN-USB Adapters and i have the older PCAN-USB Adapters with serial numbers untill 199999. It is possible for the PCAN-USB Adapters of these serial numbers to update to the newer PCAN API version and to use more than 8 PCAN-Channels?
I have the PCAN-USB Adapters with serial numbers of: 002022 199999.
If it is possible, do i have to change than some methods of the API or are they the same as the older API methods?
And do i have to install again the installer for PCAN Basic and to replace the dll in Windows\SysWOW64,...?
And an additional question for the PCAN-ISO TP and PCAN-UDS dlls, do i only have to include them to my project references or do they also need to copy to the windows folder(Windows\SysWOW64 and Windows\System32 )?
Thank you and best regards
Posted: Tue 17. Apr 2018, 13:24
by K.Wagner
did you check that your computer can see all devices by using the device manager as described in my last post? as I already said, the amount of channels to use depends on the PCAN-Basic version used and in the capabilities of your computer.
Oprogramer wrote:I checked the serial numbers of my PCAN-USB Adapters and i have the older PCAN-USB Adapters with serial numbers untill 199999. It is possible for the PCAN-USB Adapters of these serial numbers to update to the newer PCAN API version and to use more than 8 PCAN-Channels?
Neither hardware version nor firmware version have anything to do with the amount of channel that PCAN-Basic can handle.
Oprogramer wrote:And an additional question for the PCAN-ISO TP and PCAN-UDS dlls, do i only have to include them to my project references or do they also need to copy to the windows folder(Windows\SysWOW64 and Windows\System32 )?
PCAN-ISO-TP/PCAN-UDS, as well as PCAN-Basic, are native libraries - not assemblies. This mean, you cannot add them as reference. You need to include the header file to your project, that corresponds to the used programming language (for instance, PCAN-ISO-TP.cs or PCAN-UDS.cs when using C#). The dlls can be placed in the output folder of your project, or in System32/SysWow64 folder if the have to be found from everywhere in your computer.
Please let us know which version of PCAN-Basic you are using. For this, please do one of these:
- Call "CANGetValue/PCANBasic.GetValue" with the parameter PCAN_API_VERSION from your code, or
- call "CANGetValue/PCANBasic.GetValue" with the parameter PCAN_LOG_STATUS from your code, for log activation. Then, check the version number in the generated log file, or
- start one of the compiled "PCANBasicExample.exe" demo files, connect a channel, and click the button "Version"
Posted: Tue 17. Apr 2018, 14:00
by Oprogramer
Yes i checked, my computer cann see all devices. I have installed the older version of PCAN-Basic.
I have followed your recommendation and got the following informations:
- PCAN_USB 4.1.1.16099
So i checked also the PCANBasic.vb header file and recognized that it only contains 8 PCAN-USB channels.
Should i run the PCANBASIC installer again to upgrade to the newer version? And do i must replace the UDS and ISP-TP dlls in my Project to use the newer version?
Thanks and best regards
Posted: Tue 17. Apr 2018, 14:16
by K.Wagner
Oprogramer wrote:- PCAN_USB 4.1.1.16099
this is the Driver version. I need the API version. This is found in the same text from where you got the driver version. See picture:
- PCAN-basic API Version from sample exe
- API-Version.PNG (12.62 KiB) Viewed 8785 times
Oprogramer wrote:So i checked also the PCANBasic.vb header file and recognized that it only contains 8 PCAN-USB channels.
Then you have an older file, but this no mean the PCAN-Basic is old. That is why we need to check the API version. Nevertheless, in order to get the latest files, please download the PCAN-Basic package from
here. It contains header files, sample projects and libraries.
Oprogramer wrote:Should i run the PCANBASIC installer again to upgrade to the newer version?
Yes, if you have installed the PCAN-Basic using the PEAK-System-Driver-Setup (PeakOemDrv.exe). The latest version can be found
here.
Oprogramer wrote: And do i must replace the UDS and ISP-TP dlls in my Project to use the newer version?
No, just check that you are using the latest ISO-TP and UDS versions. The version history of all APIs can be seen
here.
Posted: Tue 17. Apr 2018, 14:23
by Oprogramer
sorry i looked at the false row.
The current API version i use is: 4.2.0.134
So i have to install the new PCANBASIC API.
