PCAN-USB FD with libpcap on Raspberry Pi 3
Posted: Tue 24. Apr 2018, 08:23
Hello all,
I posted same issue in libpcap's github repo.
I have a program woking well on my PC (ubuntu 16.04 amd64, with libpcap0.8 and libpcap0.8-dev installed from ubuntu apt repo, version 1.7.4) . Now I'm running that CAN bus monitor in my raspberry pi 3 and I found some issues.
While I'm opening a socketcan interface with libpcap.
In both master and libpcap-1.8 branches, pcap_datalink(hl) returned 113 (DLT_LINUX_SLL) instead of 227 (DLT_CAN_SOCKETCAN).
However on my PC it's working as expected.
FYI, my raspberry pi 3 is running Linux 4.14.33. I've recompiled the kernel to support CAN devices and my PCAN-USB FD adapter.
And I set up the CAN interface using:
I used a simple socketcan program to test sending and receiving frames and found no problem.
So I guess the problem lies in somewhere else like kernel configuration or other libraries missing or something else?
Please advice... Is there anyone ever encountered samilar issue? Any help is appreciated!
char err_buff[PCAP_ERRBUF_SIZE];
pcap_t *hl;
hl = pcap_open_live(CAN_DEV.c_str(), BUFSIZ, 1, 1000, err_buff);
if (hl == NULL)
/* open failed */
std::cout << "Couldn't open device " << CAN_DEV << std::endl;
std::cout <<" Error: " << err_buff << std::endl;
return -1;
if (pcap_datalink(hl) != DLT_CAN_SOCKETCAN)
// it is not a socketCAN frame
std::cout << "Device doesn't use socketCAN, it use " << pcap_datalink(hl) << std::endl;
return -1;
sudo ip link set can0 type can bitrate 500000 triple-sampling on
sudo ifconfig can0 up
