thaberkern
Post by thaberkern » Mon 26. Mar 2012, 16:06
Has anyone tried to compile and use the driver on a raspberry pi (http://www.raspberrypi.org)?
It contains a ARM11 CPU (Broadcom BCM2835). Fedora Linux is running well on this "machines"
Post by M.Maidhof » Tue 27. Mar 2012, 09:47
which CAN hardware from PEAK do you like to use on such a board? Do you already own such a board, or do you want to check upfront if it will be possible or not?
thaberkern
Post by thaberkern » Tue 27. Mar 2012, 10:09
I was thinking about using PCAN-USB Adapter. I'm not owning a Raspberry Pi at the moment. I was hoping to get some info first before buying the adapter an the Pi :)
If there is a chance to get it running I would buy both and invest some time to test.
Post by M.Maidhof » Tue 27. Mar 2012, 15:18
unfortunately we never heard about that board before. But when it has a USB host and the kernel source is available, I see no problem to use the PCAN-USB on an ARM device with our Linux driver. Some other users already used our linux drivers on different ARM based systems in the past (BeagleBoeard etc.)
nagilode
Post by nagilode » Fri 7. Dec 2012, 09:28
I tried to compile the driver 7.7 on a raspberry without success.
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
gcc (Debian 4.6.3-12+rpi1) 4.6.3
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE
The compilation process showed:
root@raspberrypi:~/peak-linux-driver-7.7# make KERNEL_LOCATION=/usr/src/linux PCC=NO_PCCARD_SUPPORT ISA=NO_ISA_SUPPORT PCI=NO_PCI_SUPPORT PCIEC=NO_PCIEC_SUPPORT PAR=NO_PARPORT_SUBSYSTEM VERBOSE=1
make[1]: Entering directory `/root/peak-linux-driver-7.7/driver'
make[1]: *** No rule to make target `depend'.  Stop.
make[1]: Leaving directory `/root/peak-linux-driver-7.7/driver'
*** Host machine kernel version=3.2.27+
*** Driver kernel version=3.2.21
*** Path to kernel sources=/usr/src/linux
*** use KBUILD=yes
make -C /usr/src/linux SUBDIRS=/root/peak-linux-driver-7.7/driver        EXTRA_CFLAGS="-I/root/peak-linux-driver-7.7/driver        -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT " V=1 modules
make[2]: Entering directory `/usr/src/linux-source-3.2'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (                \
        echo;                                                           \
        echo "  ERROR: Kernel configuration is invalid.";               \
        echo "         include/generated/autoconf.h or include/config/auto.conf are missing.";\
        echo "         Run 'make oldconfig && make prepare' on kernel src to fix it.";  \
        echo;                                                           \
        /bin/false)
mkdir -p /root/peak-linux-driver-7.7/driver/.tmp_versions ; rm -f /root/peak-linux-driver-7.7/driver/.tmp_versions/*
  WARNING: Symbol version dump /usr/src/linux-source-3.2/Module.symvers
           is missing; modules will have no dependencies and modversions.
make -f scripts/Makefile.build obj=/root/peak-linux-driver-7.7/driver
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_main.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/usr/src/linux-source-3.2/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /usr/src/linux-source-3.2/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_main)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_main.o /root/peak-linux-driver-7.7/driver/src/pcan_main.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_fops.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/usr/src/linux-source-3.2/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /usr/src/linux-source-3.2/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_fops)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_fops.o /root/peak-linux-driver-7.7/driver/src/pcan_fops.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_usb_core.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/usr/src/linux-source-3.2/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /usr/src/linux-source-3.2/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_usb_core)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_usb_core.o /root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c
In file included from /root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:57:0:
/root/peak-linux-driver-7.7/driver/src/pcan_usbpro.h:69:29: warning: âstruct pcan_usb_interfaceâ declared inside parameter list [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usbpro.h:69:29: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_write_notifyâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:146:47: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:156:2: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_read_notifyâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:198:31: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:206:2: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:216:33: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:218:4: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:226:4: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:243:4: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:257:16: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:259:42: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:271:30: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:272:30: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_writeâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:298:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:298:26: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:299:39: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:302:32: error: request for member âwrite_buffer_addrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:313:49: error: request for member âwrite_buffer_sizeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:315:24: error: request for member âwrite_packet_sizeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:316:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:343:25: error: request for member âwrite_packet_sizeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:344:25: error: request for member âwrite_packet_sizeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:354:3: error: request for member âwrite_dataâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:354:3: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:354:3: error: request for member âpipe_writeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:354:3: error: request for member âwrite_buffer_addrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:360:14: error: request for member âwrite_dataâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:370:4: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: At top level:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:427:47: warning: âstruct pcan_usb_interfaceâ declared inside parameter list [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_allocate_resourcesâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:430:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:437:22: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:438:22: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:442:16: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:452:13: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:454:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:455:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:456:13: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:460:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:461:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:462:13: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:466:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:475:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:476:40: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:477:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:478:40: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:485:13: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:487:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:488:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:489:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:490:12: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:494:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:495:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:497:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:498:9: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:502:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:503:22: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:505:17: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:507:4: error: request for member âwrite_buffer_addrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:507:35: error: request for member âwrite_buffer_sizeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:508:9: error: request for member âwrite_buffer_addrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:518:18: error: request for member âwrite_dataâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:522:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:523:42: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:524:13: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:533:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:533:38: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:534:38: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:537:22: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_stopâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:599:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:599:26: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:600:39: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:605:12: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:606:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:608:14: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:617:23: error: request for member âwrite_dataâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_cleanupâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:630:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:630:26: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:637:10: error: request for member âwrite_buffer_addrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_device_openâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:701:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:701:26: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:712:19: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:715:2: error: request for member âusb_timeâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:715:2: error: âPCAN_USB_TIMEâ undeclared (first use in this function)
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:715:2: note: each undeclared identifier is reported only once for each function it appears in
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:723:14: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:739:14: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_device_paramsâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:772:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:772:26: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:780:10: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:780:36: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:783:10: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:783:36: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:787:10: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:793:10: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:795:18: error: request for member âucHardcodedDevNrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:861:32: warning: âstruct pcan_usb_interfaceâ declared inside parameter list [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_create_devâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:865:37: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:866:2: error: unknown type name âUSB_PORTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:869:33: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:871:16: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:872:3: error: request for member âusb_ifâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:873:3: error: request for member âdev_ctrl_indexâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:915:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:931:29: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:935:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:936:36: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:941:26: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:945:22: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:949:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:952:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:952:40: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:959:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:962:5: error: request for member âucHardcodedDevNrâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:968:12: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:970:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_pluginâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1068:15: warning: assignment from incompatible pointer type [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1075:17: error: âpcan_usb_initâ undeclared (first use in this function)
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1084:21: error: invalid application of âsizeofâ to incomplete type âstruct pcan_usb_interfaceâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1097:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1098:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1099:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1102:2: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1103:2: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1106:2: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1108:2: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1132:3: error: unknown type name âPCAN_ENDPOINTâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1143:23: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1147:23: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1158:24: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1164:23: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1172:24: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1189:13: error: request for member âucNumberâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1190:13: error: request for member âwDataSzâ in something not a structure or union
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1200:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1200:45: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1201:8: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1201:39: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1211:2: warning: passing argument 1 of âpcan_usb_allocate_resourcesâ from incompatible pointer type [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:427:12: note: expected âstruct pcan_usb_interface *â but argument is of type âstruct pcan_usb_interface *â
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1220:7: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1222:3: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1229:14: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1236:3: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1240:22: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1242:3: warning: passing argument 1 of âpcan_usb_create_devâ from incompatible pointer type [enabled by default]
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:860:12: note: expected âstruct pcan_usb_interface *â but argument is of type âstruct pcan_usb_interface *â
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_plugoutâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1411:19: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1411:41: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1427:33: error: âunion <anonymous>â has no member named âusbâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1433:29: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1434:29: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1435:29: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1437:15: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1439:13: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1440:10: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1442:26: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_core_initâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1480:2: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1486:10: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1487:10: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1488:10: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1489:10: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1491:9: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_do_cleanupâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1507:19: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1507:41: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1512:14: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1513:11: error: dereferencing pointer to incomplete type
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c: In function âpcan_usb_deinitâ:
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1523:14: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1527:45: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1541:27: error: âstruct driverobjâ has no member named âusbdrvâ
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:1492:1: warning: control reaches end of non-void function [-Wreturn-type]
make[3]: *** [/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.o] Error 1
make[2]: *** [_module_/root/peak-linux-driver-7.7/driver] Error 2
make[2]: Leaving directory `/usr/src/linux-source-3.2'
make[1]: *** [all] Error 2
make[1]: Entering directory `/root/peak-linux-driver-7.7/lib'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/root/peak-linux-driver-7.7/lib'
make[1]: Entering directory `/root/peak-linux-driver-7.7/test'
make[1]: Leaving directory `/root/peak-linux-driver-7.7/test'
Post by M.Maidhof » Fri 7. Dec 2012, 16:28
did you modify the source of our driver?
what will lsusb show when you connect the PCAN-USB to your rhasberry Pi?
nagilode
Post by nagilode » Mon 10. Dec 2012, 11:01
thanks for your fast reply.
I reverted all modifications, used the clean tar ball from the peak website
64872ea3a301f5097eba242886ac5484 peak-linux-driver-7.7.tar.gz
and compiled again. Same problem. (Output attached)
The usb-can adapter is ordered but not here yet so I cannot tell what lsusb would show -- I do immediately if I have the adapter.
Yours
Norbert
PS: It seems that somehow USB_SUPPORT is not defined. This would at least explain the first warning:
root@raspberrypi:~/peak-linux-driver-7.7# make KERNEL_LOCATION=/root/linux/ PCC=NO_PCCARD_SUPPORT ISA=NO_ISA_SUPPORT PCI=NO_PCI_SUPPORT PCIEC=NO_PCIEC_SUPPORT PAR=NO_PARPORT_SUBSYSTEM VERBOSE=1
*** Driver kernel version=3.2.27-gada8b44
*** Path to kernel sources=/root/linux/
*** use KBUILD=yes
make -C /root/linux/ SUBDIRS=/root/peak-linux-driver-7.7/driver        EXTRA_CFLAGS="-I/root/peak-linux-driver-7.7/driver        -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT " V=1 modules
make[2]: Entering directory `/root/linux'
        echo;                                                           \
        echo;                                                           \
        /bin/false)
  WARNING: Symbol version dump /root/linux/Module.symvers
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_main.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_main)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_main.o /root/peak-linux-driver-7.7/driver/src/pcan_main.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_fops.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_fops)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_fops.o /root/peak-linux-driver-7.7/driver/src/pcan_fops.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_fifo.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_fifo)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_fifo.o /root/peak-linux-driver-7.7/driver/src/pcan_fifo.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_filter.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_filter)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_filter.o /root/peak-linux-driver-7.7/driver/src/pcan_filter.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_parse.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_parse)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_parse.o /root/peak-linux-driver-7.7/driver/src/pcan_parse.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_sja1000.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_sja1000)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_sja1000.o /root/peak-linux-driver-7.7/driver/src/pcan_sja1000.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_common.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_common)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_common.o /root/peak-linux-driver-7.7/driver/src/pcan_common.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_dongle.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_dongle)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_dongle.o /root/peak-linux-driver-7.7/driver/src/pcan_dongle.c
  gcc -Wp,-MD,/root/peak-linux-driver-7.7/driver/src/.pcan_usb_core.o.d  -nostdinc -isystem /usr/lib/gcc/arm-linux-gnueabihf/4.6/include -I/root/linux/arch/arm/include -Iarch/arm/include/generated -Iinclude  -include /root/linux/include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Iarch/arm/mach-versatile/include -Iarch/arm/plat-versatile/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -marm -fno-dwarf2-cfi-asm -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wframe-larger-than=1024 -fno-stack-protector -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -I/root/peak-linux-driver-7.7/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DNO_PCI_SUPPORT -DNO_PCIEC_SUPPORT -DNO_ISA_SUPPORT -DDONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(pcan_usb_core)"  -D"KBUILD_MODNAME=KBUILD_STR(pcan)" -c -o /root/peak-linux-driver-7.7/driver/src/pcan_usb_core.o /root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c
/root/peak-linux-driver-7.7/driver/src/pcan_usb_core.c:118:16: error: âPCAN_USB_MINOR_BASEâ undeclared here (not in a function)
make[2]: Leaving directory `/root/linux'
# ln -sf ../driver/pcan.h pcan.h
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest   -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest   -lpcan -lstdc++ -DNO_RT
cc src/bitratetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest   -lpcan -DNO_RT
cc src/filtertest.cpp src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o filtertest   -lpcan -lstdc++ -DNO_RT
cc src/pcan-settings.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcan-settings   -lpopt -g
Post by M.Maidhof » Mon 10. Dec 2012, 15:45
please use the original driver source with no modification, otherwise we can´t help you. (would have been nice to got that info about the modified code in your last post!)
nagilode
Post by nagilode » Mon 10. Dec 2012, 16:09
there is a misunderstanding.
As mentioned I used the ORIGINAL CODE (even sent you the md5sum to be sure) without modifications and the output is the same.
By the way -- the modifications I did were not related to the compilation.
Yours
Norbert
Post by M.Maidhof » Tue 11. Dec 2012, 14:11
the only explanation we see now, could be related to the following:
$ grep USB_SUPPORT src/pcan_common.h
#if !defined(CONFIG_USB_MODULE) && !defined(CONFIG_USB) && defined(USB_SUPPORT)
#undef USB_SUPPORT
=>it looks like the support of USB is not set in the Kernel you are using on your board.
please send us the output of the following command:
$ grep -e "^CONFIG_USB=" /boot/config-`uname -r`
(we don't know where the Fedora system stores the current Kernel config file, so modify the command to your system requests)
you should get this:
CONFIG_USB=y
Otherwise, the USB support is not set and you have to enable it in your system first, to use our PCAN-USB driver.
