Can't Read CAN Messeges with PCANBasic
Posted: Fri 2. Nov 2018, 08:30
by mert.sahin
I'm trying to read CAN messages. But it always returns received queue is empty. When I look at the CAN channel with PCAN View, I can see messages. Below you can find the code. It's a C# interface that reads the CAN channel when clicked on a specific button.
Looking forward to your reply.
private async void button1_Click(object sender, EventArgs e)
            StringBuilder strMsg1;
            TPCANStatus CANStatus;
            TPCANMsg ReadMessageBuffer;
            CANStatus = PCANBasic.Initialize(PCANBasic.PCAN_USBBUS1, TPCANBaudrate.PCAN_BAUD_500K);
            if (CANStatus != TPCANStatus.PCAN_ERROR_OK)
                strMsg1 = new StringBuilder(256);
                // An error occurred, get a text describing the error and show it
                PCANBasic.GetErrorText(CANStatus, 0, strMsg1);
                MessageBox.Show(strMsg1.ToString());
            else
                // Check the receive queue for new messages
                do
                    CANStatus = PCANBasic.Read(PCANBasic.PCAN_USBBUS1, out ReadMessageBuffer);
                    await Task.Delay(10);
                } while ((CANStatus & TPCANStatus.PCAN_ERROR_QRCVEMPTY) != TPCANStatus.PCAN_ERROR_QRCVEMPTY);
                if (CANStatus != TPCANStatus.PCAN_ERROR_QRCVEMPTY)
                    // Process the received message
                    if (ReadMessageBuffer.ID == 250)
                    if (ReadMessageBuffer.ID == 251)
                else
                CANStatus = PCANBasic.Uninitialize(PCANBasic.PCAN_USBBUS1);
Re: Can't Read CAN Messeges with PCANBasic
Posted: Fri 2. Nov 2018, 09:01
by K.Wagner
you are reading right after initializing the channel until "the queue is empty". This means, you probably are reading the queue before a message has the chance to get in there, so that you abandon the read loop too early. Try using a timer for reading instead. You also can try to set a delay big enough between Initialize and the Read call.
In order to generally check if you are receiving messages, please start one of the demo projects and see if it receives messages.
Posted: Fri 2. Nov 2018, 09:41
by mert.sahin
Hello Keneth,
I tried to put a delay between Initialize and the Read call but again always gives "Received Queue is Empty". I couldn't find a simpler demo of CAN_Read(). You sample C# project runs smoothly on my pc without a problem. Any other suggestions?
Regards.
Posted: Fri 2. Nov 2018, 10:36
by K.Wagner
If the PCAN-Basic example works with the same device your application is using, then your application will work too. Check that you are using the right bit rate (and right PCAN-USB channel, if you have several of them). Also check that you are not restricting the filter somewhere in your code.
In order to have a "simple demo" of any function, you can just copy the sample codes within the help file. Each method has a minimalistic sample code in each supported programming language, for instance, here the c# codes for Initialize and Read:
PCANBasic.Initialize:
TPCANStatus result;
StringBuilder strMsg;
// The Plug & Play Channel (PCAN-PCI) is initialized
result = PCANBasic.Initialize(PCANBasic.PCAN_PCIBUS2, TPCANBaudrate.PCAN_BAUD_500K);
if (result != TPCANStatus.PCAN_ERROR_OK)
    strMsg = new StringBuilder(256);
    PCANBasic.GetErrorText(result, 0, strMsg);
    MessageBox.Show(strMsg.ToString());
else
    MessageBox.Show("PCAN-PCI (Ch-2) was initialized");
// All initialized channels are released
PCANBasic.Uninitialize(PCANBasic.PCAN_NONEBUS);
PCANBasic.Read:
TPCANStatus result;
TPCANMsg msg;
do
    result = PCANBasic.Read(PCANBasic.PCAN_USBBUS1, out msg);
    if (result != TPCANStatus.PCAN_ERROR_QRCVEMPTY)
        MessageBox.Show("A message was received");
        ProcessMessage(msg);
    else
        // Here can be decided if the loop has to be  terminated (eg. the bus
        // status is  bus-off)
        HandleReadError(result);
// Try to read a message from the receive queue of the PCAN-USB, Channel 1,
// until the queue is empty
}while((result & TPCANStatus.PCAN_ERROR_QRCVEMPTY) != TPCANStatus.PCAN_ERROR_QRCVEMPTY);
Changes the codes so that the PCAN channel and bit rate fix to your needs, create a Timer with an interval of 50 milliseconds and call the Read code from there.
Posted: Fri 2. Nov 2018, 12:05
by mert.sahin
Thanks for the suggestion. I was able to read messages from CAN channel. Thanks a lot.
Regards.
