Automated File Path Directory for Save As Popup
yhadad
Post by yhadad » Tue 13. Nov 2018, 17:13
I have an automated plotter that records data once I start a macro to run a test. Once the macro completes the loop, a Save As popup window will appear so that the user can give the data file a name before saving it as shown in the code below.
Dim PlotDoc, plotter
Set PlotDoc = Documents.Open("Speed.plt")
If Not PlotDoc Is Nothing Then
     Set plotter = PlotDoc.ActiveWindow.Object
     plotter.ClearAll
     plotter.Start
End If
////(My Loop Code)////
     Plotter.Stop
PlotDoc.IsActive = True
ExecuteCommand "FilesSaveAs"
Now I need to program it to save to a specific file directory for example if the test passes, then it will have a SaveAs popup that will automatically lead to the file directory: C:\PASS and if the test will fail then a SaveAs popup will appear and automatically lead to file directory: C:\FAIL.
Is there a way of achieving that?
Thanks in advance
Kind Regards,
Yousif
M.Gerber
Design & Documentation
Re: Automated File Path Directory for Save As Popup
Post by M.Gerber » Wed 14. Nov 2018, 09:28
Hello Yousif,
Why not using the Save Method of the Document object? There you can specify a file name and a path. According to your if clause you could use the different paths and file names. Maybe in that case it wouldn't even be necessary to prompt the user with Save As anymore.
The path to the help, I've mentioned in the other thread, gives you the needed information about the Document object.
Kind regards
Mark
yhadad
Post by yhadad » Wed 14. Nov 2018, 18:34
Hi Mark,
The reason why I want a popup SaveAs with automated file directory path to a "pass" or "fail" folder is because I will have a technician at the plant that will test the e-axle and then during the popup, he will then use a QR scanner to scan the axle which will input the serial number of the axle before saving it. Thank you.
Yousif
M.Gerber
Post by M.Gerber » Thu 15. Nov 2018, 12:33
A possiblity to give a new name or just a new path as parameter to the Save As dialog does not exist.
Maybe you could go another way:
  1. Use the general InputBox function of VBscript to get the scanned serial number.
  2. Assemble the full path and name of the file to be saved in the script.
  3. Use the Save method of the Document object (i.e. PlotDoc.Save).
Hope this approach helps.
Mark
P.S.: The PCAN-Explorer Help (F1) also contains the full scripting reference by Microsoft (lowest main entry in the help's table of contents). For example, you will find the explenation for the InputBox function there.
yhadad
Post by yhadad » Thu 15. Nov 2018, 21:36
Thank you Mark,
I took your recommendation and made my code to work :) Here it is below incase someone else needs help to use my code as an example.
Dim PlotDoc, plotter, Input, fpath
     plotter.ClearAll
     plotter.Start
End If
     Plotter.Stop
Input = InputBox("Enter Serial Number")
Input = Input & ".plt"
fpath = "C:\PASS\"
PlotDoc.Save fpath & Input
MsgBox (You entered: " & Input)
