CAN stuff error in receive
jithcr
Post by jithcr » Fri 23. Nov 2018, 14:57
I am testing CAN communication between ARM based target board and Windows PC which is loaded with Peak view application.
I am able to receive the CAN packets from Peak view to target board.But I am not able to receive the CAN packet from board to PeakView Application.I am getting RX error in Trace window.
I am testing ext id.Is there any configuration has to be done on peak view application to receive the packets?
Re: CAN stuff error in receive
Post by M.Maidhof » Fri 23. Nov 2018, 15:16
please check the used baudrate settings, and use a terminated CAN cable with 120 Ohms termination resistors on both ends between CAN-L and CAN-H.
