Trouble with using LIN as slave
RS-232 to CAN/LIN Interface
Re: Trouble with using LIN as slave
Post by M.Maidhof » Mon 28. Jan 2019, 09:31
to send a subscriber frame by CAN, you need to use RTR CAN frames or the scheduler of the PCAN-LIN. Another possibility will be to generate the subscriber frame through a serial command.
See: https://www.peak-system.com/forum/viewt ... 1955#p1955
which shows a serial command for a subscriber frame on ID 0x01.
