how to change the TPUDSparameter
Posted: Wed 27. Feb 2019, 04:14
by H.Tina
Dear sir
I have a question to hope getting your help.First questio: as we all know ,in generally ,we send 10 01/02/03 to set diagnosticSessionControl.but now I want to send 10 81/82/83 to set diagnosticsession.how to change it ?
before I change the defines PUDS_SV_PARAM_DSC_DS =0x01 to PUDS_SV_PARAM_DSC_DS =0x81,it is right?
Seconed question: After I change the defines above,when I set 27 21/22,the key changes 27 A2 and the time between 27/21 and 27/22 is very long ,more than 5s.how to change it ?
best wishes
Re: how to change the TPUDSparameter
Posted: Wed 27. Feb 2019, 11:28
by F.Vergnaud
Hello H.Tina,
You should not change the definitions in the PCAN-UDS headers! The library is compiled with those definitions, changing them will not change the internal behaviour of the library.
If you want to set a specific diagnostic session simply set the correct parameter 'sessionType' when you call the function: UDS_SvcDiagnosticSessionControl(channel, msgReq, sessionType).
As for your second question, the 5s timeout may be due to the fact that the first "Session change" request was not successfull: since you're not in the right session the security access service may not be available and fail.
Posted: Thu 28. Feb 2019, 01:57
by H.Tina
Dear sir
you said can not change PCAN-UDS headers.Then how to set the correct parameter 'sessionType' when I used svcDiagnosticSessionControl(m_channel,msReq,sessiontype)?because PCAN-UDS headers didn't include 81/82/83 defines,how can use it ?can you give me an example ?
if I didn't change the PUDS_SV_PARAM_DSC_DS=0x01 to PUDS_SV_PARAM_DSC_DS=0x81,I set it as result = UDSApi.SvcDiagnosticSessionControl(m_PcanHandle, ref UDSMsg, 0x83);there is wrong in this function.the mistake is this can not matched with method
can you help me solve this problem?Thank you very much
best wishes
Posted: Thu 28. Feb 2019, 09:32
by F.Vergnaud
You simply have to cast your sessionType's value to the TPUDSSvcParamDSC enumeration like so:
UDSApi.SvcDiagnosticSessionControl(m_PcanHandle, ref UDSMsg, (UDSApi.TPUDSSvcParamDSC)0x83);
Posted: Thu 28. Feb 2019, 09:42
by H.Tina
Dear sir
if I change like this,then the time between 27 03 and 27 04 can be effected?
and if I want to change 27 03 and 27 04 to 27 21 and 27 22,Can I use the same method?or change PUDS_SVC_PARAM_SA_RSD_3 = 0x03 to PUDS_SVC_PARAM_SA_RSD_3 = 0x21?
thank you very much
best wishes
Posted: Thu 28. Feb 2019, 10:04
by F.Vergnaud
Hello H.Tina,
You, first, need to check that your SvcDiagnosticSessionControl request is answered successfully. If your ECU did not change the session, then it may not respond to your next security request (although in general it should answer with a standardized negative response code: you need to check its specifications).
Otherwise, you can safely call SvcSecurityAccess using a cast or a local variable:
// request seed
byte subFuncSeedRequest = 0x21;
sts = UDSApi.SvcSecurityAccess(Handle, ref msgReq, subFuncSeedRequest, new byte[0], 0);
Posted: Thu 28. Feb 2019, 10:37
by H.Tina
dear sir
I do it like this
status = UDSApi.SvcSecurityAccess(m_PcanHandle, ref request, 0x21, buffer, (ushort)buffer.Length);
if (status == TPUDSStatus.PUDS_ERROR_OK)
status = UDSApi.WaitForService(m_PcanHandle, out response, ref request, out request);
//calculate key
res = OK;
else
res = ERROR;
if (OK == res)
status = UDSApi.SvcSecurityAccess(m_PcanHandle, ref request, 0x22, buffer1, (ushort)buffer1.Length);
why the result is like this
02 27 21 00 00 00 00 00
06 67 21 12 13 12 12 00
06 27 A2 23 32 43 27 00
why 22 become A2?
best wishes
Posted: Thu 28. Feb 2019, 11:56
by F.Vergnaud
Keep in mind that only checking the result of the WaitForService function is not enough ; you need to check that:
- - the received response is positive (meaning that a message was replied, but it can contain error, see TPUDSMsg.IsPositiveResponse method)
- and is not a negative answer (message is holding a NRC code, see TPUDSMsg.IsNegativeResponse).
In your case it doesn't seems to be the case (assuming that "06 67 21 12 13 12 12 00" is the ECU's answer). In the future, please provide the complete trace of your CAN bus communication (including CAN IDs) in order to better understand your log.
Anyway, as far as I can tell it seems that you have set the request's member "NO_POSITIVE_RESPONSE_MSG" to "PUDS_SUPPR_POS_RSP_MSG_INDICATION_BIT" flag: it adds the value 0x80 to the first parameter of the request (0xA2 = 0x80 + 0x22).
Since you re-use the same object for your calls to SvcSecurityAccess, please make sure that the member NO_POSITIVE_RESPONSE_MSG of your object "request" is set to 0.
Posted: Fri 1. Mar 2019, 02:44
by H.Tina
Dear sir
I want to know how to set the NO_POSITIVE_RESPONSE_MSG =0.I do like this :
//postivite response
if (response.DATA[0] == 0x67 && response.DATA[1] == 0x21)
res = OK;
else
res = ERROR;
if (OK == res)
if (response.DATA[0] == 0x67)
res = OK;
else
res = ERROR;
the result is the same as the last topic,the second is still 27 A2.can you tell me how to change it ?
in my mind ,I have a method to solve it ,but I don't know is it right?After send 27 21 and receive positive response ,then I set "request =new request" again like this
res = OK;
else
res = ERROR;
if (OK == res)
request = new TPUDSMsg();
request.NETADDRINFO.SA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT;
request.NETADDRINFO.TA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_ECU_8;
request.NETADDRINFO.TA_TYPE = TPUDSAddressingType.PUDS_ADDRESSING_PHYSICAL;
request.NETADDRINFO.RA = 0x00;
request.NETADDRINFO.PROTOCOL = TPUDSProtocol.PUDS_PROTOCOL_ISO_15765_2_11B;
is this method right?if it is wrong ,please tell the right method to solve this problem.
I have find that if I send 10 01/02/03 didn't 10 81/82/83,even if I re-use the same request and don't new it again,it has no this problem.it still send 27 22
Posted: Fri 1. Mar 2019, 09:28
by F.Vergnaud
Simply use the following:
request.NO_POSITIVE_RESPONSE_MSG = 0;
Otherwise your alternative solution is also ok.
The function UDSApi.WaitForService(m_PcanHandle, out response, ref request, out request); uses the 'out' keyword for the last parameter, this explains why the object 'request' can be modified.
