Kernel message: PCIe Bus Error when receiving messages
Posted: Thu 21. Mar 2019, 18:01
Hi, we have PCAN-M.2 Four Channe IPEH-004085 series-no: C1/118 in my device, two CANs port are connected. When they are receiving the messages, the system reports the following error message.
We had Arch Linux custom real-time kernel. The CAN_PEAK_PCIEFD module was included. Messages can be read from the card. But the flooding error messages bother me so much.
It worked fine without any error message in the normal kernel on the same hardware system. Is there any specific kernel model we should include other than the CAN_PEAK_PCIEFD?
We have enabled: CAN_PEAK_PCI + CAN_PEAK_PCIEC + CAN_PEAK_PCIEFD + CAN_PEAK_USB
We tried to add grub command such as setting pci=nommconf or pci=noaer or pcie_aspm=off or pci=nomsi None of them helped.
We did some experiments that by presenting one of the CAN by "ip link set", the error message disappeared. But after we reset the other can port, the message flooded again.
Here is some dmesg releated to peak:
Hardware Info:
gigabyte mother board https://www.gigabyte.com/Motherboard/GA ... -rev-10#kf
AMD Ryzen 7 1700 Eight-Core Processor
Thanks!
Roger
pcieport 0000:00:01.1: AER: Corrected error received: 0000:00:00.0
pcieport 0000:00:01.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
pcieport 0000:00:01.1: device [1022:1453] error status/mask=00000040/00006000
pcieport 0000:00:01.1: [ 6] BadTLP
[ 0.294121] CAN device driver interface
[ 0.294134] usbcore: registered new interface driver peak_usb
[ 0.294182] peak_pciefd 0000:01:00.0: 4x CAN-FD PCAN-PCIe FPGA v3.2.1:
[ 0.294268] peak_pciefd 0000:01:00.0: can0 at reg_base=0x00000000efadab57 irq=46
[ 0.294332] peak_pciefd 0000:01:00.0: can1 at reg_base=0x0000000011fceca6 irq=46
[ 0.294388] peak_pciefd 0000:01:00.0: can2 at reg_base=0x0000000061e0cde5 irq=46
[ 0.294444] peak_pciefd 0000:01:00.0: can3 at reg_base=0x00000000d7541f72 irq=46
[ 0.294458] sja1000 CAN netdevice driver
[ 0.294496] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 0.294497] e100: Copyright(c) 1999-2006 Intel Corporation
[ 0.294510] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 0.294511] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.294525] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 0.294525] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.294541] sky2: driver version 1.30
[ 0.300212] libphy: r8169: probed
[ 0.300418] r8169 0000:0a:00.0 eth0: RTL8168g/8111g, e0:d5:5e:24:90:8d, XID 4c0, IRQ 47
[ 0.300420] r8169 0000:0a:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
H/W path Device Class Description
system AB350N-Gaming WIFI (Default string)
/0 bus AB350N-Gaming WIFI-CF
/0/0 memory 64KiB BIOS
/0/25 memory 16GiB System Memory
/0/25/0 memory 8GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2400 MHz (0.4 ns)
/0/25/1 memory [empty]
/0/25/2 memory 8GiB DIMM DDR4 Synchronous Unbuffered (Unregistered) 2400 MHz (0.4 ns)
/0/25/3 memory [empty]
/0/27 memory 768KiB L1 cache
/0/28 memory 4MiB L2 cache
/0/29 memory 16MiB L3 cache
/0/2a processor AMD Ryzen 7 1700 Eight-Core Processor
/0/100 bridge Family 17h (Models 00h-0fh) Root Complex
/0/100/0.2 generic Family 17h (Models 00h-0fh) I/O Memory Management Unit
/0/100/1.1 bridge Family 17h (Models 00h-0fh) PCIe GPP Bridge
/0/100/1.1/0 can1 network PEAK-System Technik GmbH
/0/100/1.3 bridge Family 17h (Models 00h-0fh) PCIe GPP Bridge
/0/100/1.3/0 bus 300 Series Chipset USB 3.1 xHCI Controller
/0/100/1.3/0/0 usb1 bus xHCI Host Controller
/0/100/1.3/0/0/a communication Bluetooth wireless interface
/0/100/1.3/0/1 usb2 bus xHCI Host Controller
/0/100/1.3/0.1 storage 300 Series Chipset SATA Controller
/0/100/1.3/0.2 bridge Advanced Micro Devices, Inc. [AMD]
/0/100/1.3/0.2/0 bridge 300 Series Chipset PCIe Port
/0/100/1.3/0.2/1 bridge 300 Series Chipset PCIe Port
/0/100/1.3/0.2/4 bridge 300 Series Chipset PCIe Port
/0/100/1.3/0.2/5 bridge 300 Series Chipset PCIe Port
/0/100/1.3/0.2/5/0 wlp8s0 network Wireless 3165
/0/100/1.3/0.2/6 bridge 300 Series Chipset PCIe Port
/0/100/1.3/0.2/7 bridge 300 Series Chipset PCIe Port
/0/100/1.3/0.2/7/0 enp10s0 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/3.1 bridge Family 17h (Models 00h-0fh) PCIe GPP Bridge
/0/100/3.1/0 display GP106 [GeForce GTX 1060 6GB]
/0/100/3.1/0.1 multimedia GP106 High Definition Audio Controller
/0/100/7.1 bridge Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
/0/100/7.1/0 generic Advanced Micro Devices, Inc. [AMD]
/0/100/7.1/0.2 generic Family 17h (Models 00h-0fh) Platform Security Processor
/0/100/7.1/0.3 bus Family 17h (Models 00h-0fh) USB 3.0 Host Controller
/0/100/7.1/0.3/0 usb3 bus xHCI Host Controller
/0/100/7.1/0.3/1 usb4 bus xHCI Host Controller
/0/100/8.1 bridge Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
/0/100/8.1/0 generic Advanced Micro Devices, Inc. [AMD]
/0/100/8.1/0.2 storage FCH SATA Controller [AHCI mode]
/0/100/8.1/0.3 multimedia Family 17h (Models 00h-0fh) HD Audio Controller
/0/100/14 bus FCH SMBus Controller
/0/100/14.3 bridge FCH LPC Bridge
/0/101 bridge Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
/0/102 bridge Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
/0/103 bridge Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
/0/104 bridge Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
/0/105 bridge Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
/0/106 bridge Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
/0/107 bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0
/0/108 bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1
/0/109 bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2
/0/10a bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3
/0/10b bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4
/0/10c bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5
/0/10d bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6
/0/10e bridge Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7
/0/1 scsi4 storage
/0/1/0.0.0 /dev/sda disk 500GB Samsung SSD 850
/0/1/0.0.0/1 /dev/sda1 volume 1023KiB BIOS Boot partition
/0/1/0.0.0/2 /dev/sda2 volume 465GiB EXT4 volume
/1 docker0 network Ethernet interface
Thanks!
Roger
