Changing the x axis of plotter add-in
Ruud van Dijk
Post by Ruud van Dijk » Fri 2. Aug 2019, 10:13
is it possible to change the x axis from date and time to a specific byte or bytes?
For example, we want to use an RPM signal and set that against other signals.
That way we could see how much gas is being given at a speed and gear at specific RPMs.
Or is there an option to make a 3D mapping at PEAK?
Ruud van Dijk
Re: Changing the x axis of plotter add-in
Post by M.Maidhof » Fri 2. Aug 2019, 12:26
the Plotter Add-In only offers a time based x axis. With PCAN-Explorer we don't offer such a mapping. But you can use the PCANBasic API and build an own application which will display the CAN data in your requested form.
Ruud van Dijk
Post by Ruud van Dijk » Fri 2. Aug 2019, 12:44
Hello Michael
thank you very much for your answer. I'm going to discuss this with our software engineer, to build such an application.
Best regard,
Ruud van Dijk
