Upload mere than 7 bytes (block mode)
Posted: Mon 2. Sep 2019, 15:15
by waszniowski
I am able to successfully upload up to 7 bytes (standard mode) via blocking call of
msg = new byte[20];
result = XCPApi.Upload(m_XcpSession, 7, msg, (ushort)msg.Length);
Attempt to upload more bytes in block mode, however, returns out of range err without sending any message to bus.
How can I upload in block mode?
Libor
Re: Upload mere than 7 bytes (block mode)
Posted: Mon 2. Sep 2019, 17:00
by K.Wagner
you can not request more than 7 bytes with this function. The function doesn't support blocking mode.
Posted: Tue 3. Sep 2019, 08:16
by waszniowski
Thank you very much for your fast response.
Is there another way how to implement block mode upload (Command Code = 0xF5, Number of data elements > 7)?
Posted: Tue 3. Sep 2019, 08:18
by K.Wagner
Hello again,
just a clarification: The API functions cannot handle more than MAX_CTO for an answer. When you use any function and gives a buffer for a CTO, the function will fail if the result may be bigger than 8 bytes.
Try using the function asynchronously, i.e. set the "ctoBuffer" on the function call to NULL. Then, the upload request should get out and you will receive more CTO packages that can be read using the function XCP_DequeuePacket. More information regarding reading asynchronously can be read in the help at chapter "Introduction/About PCAN-XCP/Synchronous vs. Asynchronous Package Receiving"
I hope this help,
Posted: Tue 3. Sep 2019, 15:39
by waszniowski
Thanks you very much - it works.
What is surprising for me is, that
result = XCPApi.Upload(m_XcpSession, num);
returns error code
XCP_ERR_CMD_SYNCH
(but there is no corresponding message from slave on the bus). If I ignore this error code, I can successfully read data via XCPApi.DequeuePacket(...).
Posted: Tue 3. Sep 2019, 15:46
by K.Wagner
you are right. This is a small bug. Just ignore this error by now. We will fix this in the next version.
Thanks for bringing this into our attention.
