U.Wilhelm
Post
by U.Wilhelm » Mon 18. Nov 2019, 12:18
you wrote:
During transmission another thread is constantly reading data using CAN_read(), another one ditto for the 2nd channel.
what we are talking about? - call read every 1000ms, 100ms, 10ms or some µs ?!?
In the documenation you find some hint that you should read ALWAYS until you get the CAN_ERR_QRCVEMPTY (receive queue of the DRIVER is empty)
Calling for every CAN-Frame a single CAN Read is not correct - change it and you will see that it works (thousends of other applications work like that and work perfectly since many years..)
DF1AS
Post
by DF1AS » Mon 18. Nov 2019, 21:17
We cannot use interrupts or call-backs, so it's good practice to spend threads for active polling (at the cost of some CPU load). It works perfectly for the PCAN-light version (no noticeable side effects as expected), so we stay with and do not switch to PCAN-basic. PCAN-basic also works that way but slows down. Thank you for helping us.
Kay
U.Wilhelm
Post
by U.Wilhelm » Tue 19. Nov 2019, 08:27
no one say that you need to use interrupt or callbacks (which is definitally the best way) you should simply read ALL CAN MSGs in the queue until it is empty - as we wrote - do not read only single CAN Frames. The DLL implementation is not much changed in the past - beliveie me the PCAN-Light and the PCAN-Basic use both the same driver implementation. Most changes are made inside the driver.
You also did not answer any in of how often you "poll" the queue - as we wrote - not to much (5-10ms) but then read all entries...thousend of application work well .. so why should only your´s doesn´t ?
