PCAN Driver Linux Raspberry Pi
Posted: Mon 30. Mar 2020, 11:38
by JeanSmith
I am trying to install the driver: https://www.peak-system.com/fileadmin/m ... /index.htm on my Raspberry Pi 2B, with Raspbian (Version:February 2020
Release date:2020-02-13, Kernel version:4.19).
I followed the instruction in the documentation chatper 3 in: https://www.peak-system.com/fileadmin/m ... /index.htm. Unfortunately i didn't get so far. I got following error.
I appreciate every help. Thanks
pi@raspberrypi:~/peak-linux-driver-8.10.0 $ make
make[1]: Verzeichnis „/home/pi/peak-linux-driver-8.10.0/driver“ wird betreten
*** Host OS Release=Raspbian GNU/Linux v10
*** Host machine kernel version=4.19.97-v7+
*** Driver kernel version=4.19.97-v7+ (4.19.97)
*** Path to kernel sources=/usr/src/linux-headers-4.19.97-v7+
*** use KBUILD=yes
*** gcc version=8
make -C /usr/src/linux-headers-4.19.97-v7+  EXTRA_CFLAGS="-I/home/pi/peak-linux-driver-8.10.0/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT   -Wno-date-time" V=0 modules SUBDIRS=/home/pi/peak-linux-driver-8.10.0/driver
make[2]: Verzeichnis „/usr/src/linux-headers-4.19.97-v7+“ wird betreten
  CC [M]  /home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.o
/home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.c: In function ‘pcan_pci_enable_msi’:
/home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.c:272:2: error: implicit declaration of function ‘pci_alloc_irq_vectors_affinity’; did you mean ‘pci_alloc_consistent’? [-Werror=implicit-function-declaration]
  pci_alloc_irq_vectors_affinity(a, b, c, PCI_IRQ_MSI, NULL)
/home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.c:369:18: note: in expansion of macro ‘pcan_pci_enable_msi_range’
  pa->msi_count = pcan_pci_enable_msi_range(pa->dev, 1, msi_max);
/home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.c:272:42: error: ‘PCI_IRQ_MSI’ undeclared (first use in this function); did you mean ‘PCI_IOBASE’?
/home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.c:272:42: note: each undeclared identifier is reported only once for each function it appears in
make[3]: *** [scripts/Makefile.build:304: /home/pi/peak-linux-driver-8.10.0/driver/src/pcan_pci.o] Fehler 1
make[2]: *** [Makefile:1522: _module_/home/pi/peak-linux-driver-8.10.0/driver] Fehler 2
make[2]: Verzeichnis „/usr/src/linux-headers-4.19.97-v7+“ wird verlassen
make[1]: *** [Makefile:508: all] Fehler 2
make[1]: Verzeichnis „/home/pi/peak-linux-driver-8.10.0/driver“ wird verlassen
make: *** [Makefile:72: all] Fehler 2
Re: PCAN Driver Linux Raspberry Pi
Posted: Mon 30. Mar 2020, 12:09
by M.Heidemann
When installing our driver on a raspbian system, there are a few things to note. (You need to install the Kernel-headers, for example)
Have you seen the post by my colleague Michael?
viewtopic.php?f=59&t=3381&p=11967&hilit=raspbian#p11967
This post exaplains in detail how you get our driver to work on a raspbian system.
Please follow the steps outlined in the forum post first and see if this resolves your issue.
Please report back to me, if you were able to make it work.
Posted: Mon 30. Mar 2020, 13:38
by JeanSmith
Hello Marvin,
thanks you for your reply. Yes it helped. Now i got it work.
But when i am starting candump: "candump any" for example, i do not get any output.
Also when i am starting the PCAN View for Linux, i got the following message:
Error: Unable to get any valid combiination of BRP/ TSEGx/ SJW for bitrate=2000000 bps, clock=80MHz and Sample Point 7,5o. But i am not able to change the settings.
Do you have an idea , why?
Posted: Mon 30. Mar 2020, 14:25
by M.Heidemann
Hello Jean,
Please note:
There are 2 variants of our driver that serve different purposes:
CharDev driver: This driver is compatible with our PCANBasic API and PCAN-View for Linux. This version is not compatible with SocketCAN (Which candump uses)
NetDev driver: Compatible with the SocketCAN API and the CAN-utilities, such as candump, cansend , etc. This variant does not support PCANBasic and PCAN-View for Linux.
What is your intended usage and which variant of the driver did you install?(Note that the mentioned thread describes both variants)
Posted: Tue 31. Mar 2020, 11:44
by JeanSmith
Hello Marvin,
thanks again. okay, if i understand it correctly: just with adding: "NET=NETDEV_SUPPORT" to "make PCC=NO PCI=NO ISA=NO DNG=NO", i can change from the chardev driver (which is the preconfigured driver) to the NETDEV driver?
Now i got both working. But with the NetDev Driver i still get no output with the command "candump any". I have to send a message with "cansend" from an other terminal to see any output.
My goal is to see the whole canbus traffic. With the CharDev driver und Canview it seems that i can see the whole traffic.
Is there a possibility to see the whole canbus traffic with candump ?
Best regards
Jean
Posted: Tue 31. Mar 2020, 12:01
by M.Heidemann
Hello Jean,
You cannot run both drivers at the same time, you may uninstall the undesired driver before installing the driver you need.
Switching between them would be done by uninstalling the current driver and then rebuilding and reinstalling the other driver.
Regarding candump:
How do you "bring up" (sudo ip link ... ) the device and does it match the bitrate / protocol you have to use (CAN/CAN FD)?
Using the same settings (by sending with the same device) will yield results since the configuration is the same.
Have you compared the Bitrate settings of PCAN-View with the one you want to use with SocketCAN?
Posted: Wed 1. Apr 2020, 09:35
by JeanSmith
Regarding candump:
- i have compared both bitrates and tried to use for both the same
- i "bring it up" with: "sudo ip link set can0 type can bitrate 5000" and "sudo ip link set up can0"
I have also tried some other bitrate settings, but it doesn't work
Posted: Wed 1. Apr 2020, 09:47
by M.Heidemann
Using SocketCAN a bitrate-setting of 5000 would equate to 5Kb/s, which is quite the low bitrate.
Did you intent to use 500Kb/s? Then the bitrate would have to be configured as 500000.
Also you can combine the commands like this:
sudo ip link set can0 up type can bitrate 500000
Also bitrates below 25Kb/s are not supported by our FD-interfaces (For example the PCAN-USB FD), see the product page under "technical specifications":
https://www.peak-system.com/PCAN-USB-FD.365.0.html
The PCAN-USB does support this bitrate, as you can see on the product page under "technical specifications":
https://www.peak-system.com/PCAN-USB.199.0.html
So this also a questions of whether or not the hardware you use is suited for your application.
May i ask which device you currently use?
Also what is you current setup and what devices are involved on the bus?
