Support of Visual Studio Code using new DevPack for Router Pro?
Posted: Thu 2. Apr 2020, 18:31
by Dominik M.
Dear PEAK-Support Team,
By reading your news article and the product homepage for your new PEAK PCAN-Router FD Pro I recognized that you also released a new development package which supports Visual Studio Code:
http://www.peak-system.com/quick/DLP-Router-Pro-FD
Since in this package also contains examples for the "normal" bare PCAN-Router I was wondering if I could use this new DevPack / Visual Studio Code also to compile the "old" examples of the PCAN Router Pro (https://www.peak-system.com/fileadmin/m ... ro_dev.zip)? So that I could use the new IDE to develop a router configuration for our PCAN-Router Pro (would make things a bit more comfortable :) ).
I guess it should work (by copying them into a subfolder and running your SetPath_for_VSCode.vbs script), but I just would like to reconfirm before...
Thank you
Dominik
Re: Support of Visual Studio Code using new DevPack for Router Pro?
Posted: Fri 3. Apr 2020, 09:01
You are right - that will work exact in the same way. You have to copy the Example Directory in a SUB Folder and call the VBScript again.
You do NOT need to install any compiler for the Router Pro if you already use the new package - copy only the Samples. I just tested it and it works out of the box !
Posted: Tue 7. Apr 2020, 15:05
by Dominik M.
I just wante to confirm that the PEAK Router Pro Examples can be compiled using Visual Studio Code as you described!
Maybe that's also something you could mention on the Router Pro product homepage (or consider an update of the dev package ;) ).
Thank you!
Posted: Tue 7. Apr 2020, 15:17
Thank you for the feedback. We are working on a new package that will include all ARM based Hardware.
As soon as we have made all testst , we will offer the package inluding also the Router Pro.
