UDS Client Sample Project DLL problem in Visual studio 2017
Posted: Tue 28. Apr 2020, 13:15
by Shail
we are using PCAN-UDS.lib in sample project PCAN UDS (C++)API Package.
(1) How to make use of PCAN-UDS.dll in visual studio 2017?
Stpes already tried to make use of dll :
(1) Right Click on PCAN_Client Solution.
Configuration Properties -> General -> Additional directories -> Path of DLL Added
(2) Right Click on PCAN_Client Solution.
Configuration Properties -> Linker-> input-> Additional dependencies-> Path of DLL Added
Configuration Properties -> Linker -> General -> Additional Library directories-> Path of DLL Added
Still We are Not able to make use of PCAN-UDS.dll.
(2) How we can import DLL Library ? Please provide steps using example.
When I am using this way DLL = LoadLibrary(_T("PCAN-UDS.dll?")); We are getting hrReturnVal = ERROR_DELAY_LOAD_FAILED.
(3) How we can use external(3rd party) DLL xxxx.dll with PCAN UDS project in visual studio 2017?
We only need to call function from external dll to main project PCAN UDS
Re: UDS Client Sample Project DLL problem in Visual studio 2017
Posted: Tue 28. Apr 2020, 14:39
by M.Heidemann
Thank you for your request:
1)
Make sure that you copied the correct architecture of the dlls in SysWOW64 and System32, on a 64 bit Windows it will be:
- System32: copy the x64 dlls,
- SystemWOW64: copy the Win32 dlls.
Also check if both PCANBasic and the PCAN-ISO TP API are both correctly installed.
2) and 3) Bot of these questions are related to development concepts in C++. You should read up on them online.
Posted: Wed 29. Apr 2020, 15:02
by Shail
Thanks for reply.
we have put dlls in SysWOW64 and System32, on a 64 bit Windows it will be:
1) Can u tell where we need to placed PCAN-UDS.dll?
2) Example how to use UDS_Initialize function using PCAN-UDS.dll?
Posted: Wed 29. Apr 2020, 16:26
by M.Heidemann
Did you have a look at the examples supplied with the PCAN_UDS-API?
If yes, do you use one of these as a basis?
You could have a look at /SAMPLES/PCAN-UDS/C++/PCUCLIENT/PCUClient.cpp:
It includes the PCAN-UDS Header file for c++
UDS_Initialize used in line 1176
// Set the PCAN-Channel to use (PCAN-USB Channel 1)
Channel = PUDS_USBBUS1;
// Initializing of the UDS Communication session
Status = UDS_Initialize(Channel, PUDS_BAUD_250K, 0, 0, 0);
printf("Initialize UDS: %i\n", (int)Status);
// Define Address
iBuffer = PUDS_SERVER_ADDR_TEST_EQUIPMENT;
Status = UDS_SetValue(Channel, PUDS_PARAM_SERVER_ADDRESS, &iBuffer, 1);
printf(" Set ServerAddress: %i (0x%02x)\n", (int)Status, iBuffer);
// Define TimeOuts
ulBuffer = 2000;
Status = UDS_SetValue(Channel, PUDS_PARAM_TIMEOUT_REQUEST, &ulBuffer, sizeof(ulBuffer));
printf(" Set TIMEOUT_REQUEST: %i (%d)\n", (int)Status, ulBuffer);
Status = UDS_SetValue(Channel, PUDS_PARAM_TIMEOUT_RESPONSE, &ulBuffer, sizeof(ulBuffer));
waitGetch();
// Define Network Address Information used for all the tests
N_AI.SA = PUDS_SERVER_ADDR_TEST_EQUIPMENT;
N_AI.TA = PUDS_ISO_15765_4_ADDR_ECU_1;
N_AI.TA_TYPE = PUDS_ADDRESSING_PHYSICAL;
N_AI.RA = 0x00;
N_AI.PROTOCOL = PUDS_PROTOCOL_ISO_15765_2_11B;
may you could tell me, what exactly you need to do in case i misunderstand your request.
Posted: Wed 29. Apr 2020, 18:19
by Shail
(1) Did you have a look at the examples supplied with the PCAN_UDS-API? : Yes
(2) If yes, do you use one of these as a basis?
Yes. Same one
In same example PCUClient.cpp code using PCAN-UDS.lib as library.
AS Check by Configuration Properties-> General->linker->Input-> Additional Dependencies->Libs\x64\PCAN-UDS.lib;%(AdditionalDependencies)
(3) Que: In placed of PCAN-UDS.lib how we can make use of only PCAN-UDS.dll?
What are the changes required to make use of PCAN-UDS.dll?
is not possible or not supported to only make use of PCAN-UDS.dll?
Posted: Thu 30. Apr 2020, 09:38
by M.Heidemann
You cannot use the .lib as a library.
the .lib file contains a list of the exported functions and data elements from the library and to which DLL they are associated. When the linker builds the final executable then if anything from the library is used then the linker adds a reference to the DLL and adds entries to the executables import table so that calls to the referenced functions is redirected to the DLL.
It is not required to use a .lib file to use a DLL, but without it you'll not be able to use functions from the DLL as regular functions in your code. In this case you have to manually call LoadLibrary to load the DLL.
You will need to use GetProcAddress to get the address of the function or data item in the DLL. You must then cast the returned address to an appropriate pointer-to-function in order to use it.
(Use FreeLibrary to free the loaded library afterwards).
If you want to use the .DLL exclusively in the example you will have the change the whole code accordingly, that means everytime a data item or a function of the library is used you`ll need to manually load the library, get the adress of the data item or function in that DLL, the returned address needs to be cast as the right pointer-to-function. Then free the loaded library once you are done with it.
