Export PPCAN-Editor configuration as binary file?
Posted: Wed 28. Oct 2020, 21:35
Dear PEAK-Team,
I'm wondering if it is possible to export / compile a binary image of a PCAN Router Pro configuration created with your PPCAN-Editor. Another user of the router should not be able to (deeply) analyse the used CAN-DBC (CAN signals/messages) for creating the router configuration (as well as not be able to accidentally change something of the configuration. So I would like to provide a binary file which just simply be flashed on the unit using PEAK-Flash. It doesn't have to be a binary, as long it is a "non-readable" file to be flashed into the unit using either PEAK-Flash or the PPCAN-Editor.
Is something like that possible and if so what would be the steps to create the firmwar image?
Thank you for your support!
