I try to send several messages to the bus using CAN_Write. One message is for the interface, which displays a text, the other for an actuator.
If I use the CAN_Write command twice in a row, the interface starts flickering and the messages switch.
Is there a solution using a list for those two messages or how could i solve this?
Best Regards and thank you for reply
Johannes
Transmitting several CAN messages
Re: Transmitting several CAN messages
Thank you for your request.
To further assess the issue, we need the following information:
Which OS do you sue?
Which API do you use?
Which PCAN-OEM driver version do you use?
