CAN-Interface for PCI Express Mini
Open up the Registry-Editor:
Hardware1 = HardwareHandle1,
Hardware2 = HardwareHandle2
etc.
- Hardware-Type
  • 0x113 = PCAN-PCI Express FD
  • 0x108 = PCAN-miniPCIe
  • 0x118 = PCAN-miniPCIe FD
  • 0x10A = PCAN-ExpressCard 34
  • 0x109 = PCAN-Chip PCIe
  • 0x119 = PCAN-Chip PCIe FD
  • 0x11A = PCAN-M.2
- Controller-Number (Channel)
- Device-number
Below an example:
viewtopic.php?f=120&t=998
