Can't Recieve Data on CAN
vivekjaiswal1
Post by vivekjaiswal1 » Fri 26. Feb 2021, 12:49
I have PCAN-PCI Express FD Device. I installed the drivers as mentioned in the manual.
 cd ~/PCAN-Driver
make NET=NETDEV_SUPPORT PCI=PCI_SUPPORT PCIEC=PCIEC_SUPPORT
sudo make install
But While using PCANVIEW I am getting following error
Screenshot from 2021-02-26 17-04-35.png (45.19 KiB) Viewed 5638 times
And while using the terminal commands to see the data. There no data is published
Screenshot from 2021-02-26 17-10-46.png (14.73 KiB) Viewed 5638 times
Any help would be highly appreciated.
Screenshot from 2021-02-26 17-13-53.png (31.91 KiB) Viewed 5638 times
Re: Can't Recieve Data on CAN
Post by M.Heidemann » Fri 26. Feb 2021, 12:58
PCAN-View for Linux is not compatible with the NetDev-Driver (SocketCAN) and only works with the CharDev-variant of our proprietary Linux driver exclusively.
As to why there are no messages displayed with candump:
1) Is your CAN-bus properly terminated (120 Ohms) on both bus-ends?
2) Does the bitrate match the biotrate used by alll other CAN-nodes on the bus?
3) What kind of CAN-data are you expecting to see, are you sure there are any messages transmit at the moment of reading?
vivekjaiswal1
Post by vivekjaiswal1 » Fri 26. Feb 2021, 13:22
Hi Marvin,
Thank you for the prompt reply. Actually initially installing the driver. I installed in the drivers without NETDEV_SUPPORT. At that time pcanview was working fine and displaying the data also.
I wanted to use SOCKETCAN so I installed drivers with NETDEV but no data is being published.
Vivek
Post by M.Heidemann » Fri 26. Feb 2021, 13:35
Thank you for your response.
As mentioned earlier:
- Does the bitrate match the bitrate used by alll other CAN-nodes on the bus?
- What kind of CAN-data are you expecting to see, are you sure there are any messages transmit at the moment of reading?
We need more information on what exactly are the conditions at the very moment to provide adequate support.
Furthermore it would be helpful to know, which bitrate configuration you have used with PCANView previously.
vivekjaiswal1
Post by vivekjaiswal1 » Fri 26. Feb 2021, 13:49
I have currently attached only a Continental RADAR on CAN bus 0. As prescribed by the sensor manufacturer I am using 500k bitrate.
And there is no transmitting of any message while receiving data. However, is there any way to verify this?
Post by M.Heidemann » Fri 26. Feb 2021, 14:28
If there is no message present on the bus, candump will be unable to display anything as there is nothing to display...
Well, you could verfiy using a know working configuration and see if the radar transmits data in this state.
However you could try, this, as you were previously to see can-traffic with PCAN-View:
sudo ip link set can0 up type can bitrate 500000 sample-point 0.8
As PCAN-View seems to have used 500k with a sample-point of 80% previously,
you should try the same configuration when using socketcan.
Please report back to us, if this has solved the issue.
vivekjaiswal1
Post by vivekjaiswal1 » Fri 26. Feb 2021, 14:39
I am new to using PCAN Converters. Do I need to somehow link /dev/pcan0 to can0. Or is it automatically done while installing drivers.
Post by M.Heidemann » Fri 26. Feb 2021, 14:50
When installing the driver as netdev,
this is automatically configured accordingly.
vivekjaiswal1
Post by vivekjaiswal1 » Fri 26. Feb 2021, 15:41
Please correct me If I am wrong in the following procedure for initializing the CAN drivers:
 sudo modprobe pcan
 candump can0
Post by M.Heidemann » Mon 1. Mar 2021, 07:14
This is the correct order, however:
sudo modprobe pcan
will only be necessary once, right after the driver has been installed.
On the next boot the driver will automatically be loaded.
Please report back to us, if the bitrate configuration we've suggested worked
