SFF PC case and PCI Express card & MITM Device
Posted: Sat 1. May 2021, 13:56
I presume the dual port PCAN PCI-Express card IPEH-004027 will be too high/tall to fit into an Dell Optiplex 790 SFF case.
Is there a short version?
If it could fit then can the dual CAN port PCI express card act as a MITM device with the PC Explorer 5 software on a 500kbps bus?
Can it pass data back and forth if inserted into a working bus while i manipulate packets using the explorer software if necessary?
i.e. CANBUSA <<<<<<>>>>>>> PCAN E PortA <EXPLORER 5> PCAN E PortB <<<<<<<>>>>>> CANBUSA
