PCAN-Router Pro Library(C/C++)
Posted: Mon 19. Jul 2021, 18:29
by shammi256
I want to configure PCAN_Router Pro from command line or C/C++ application. Do you have command line based configuration tool or library except PPCAN-Editor 2 ?
Re: PCAN-Router Pro Library(C/C++)
Posted: Tue 20. Jul 2021, 08:53
by M.Heidemann
Thank you for your request.
We provide two methods of configuring the PCAN-Router Pro:
- Using PPCAN-Editor 2 to configure the device
- Writing and flashing your own firmware for it. (Requires programming knowledge)
PPCAN-Editor 2 does not provide configuration via CMD.
The second option could be sommewhat automated, as the PCAN-Router Pro can be put into bootloader mode via firmware. See example Hardware\PCAN-Router_Pro\Examples\04_BOOTLOADER of the Peak-DevPack regarding this:
https://www.peak-system.com/quick/DLP-DevPack
This however will only speed up the flashing process, changes in the firmware
still have to be done manually before compiling and flashing.
For faster changes to a configuration PPCAN-Editor 2 most likely is the better option.
marvin
