Interfacing transport layer code
RS-232 to CAN/LIN Interface
driverobot
Post by driverobot » Tue 3. Aug 2021, 02:23
Hello!
I am trying to interface my LIN dongle to emulate as one of the slaves nodes in my car. I want to integrate it in my test setup.
I am looking for some interfacing code which can act as the transport layer for this module. I do not want to go through the effort of parsing all serial responses to get my LIN data.
A python library would be great :D
DriveRobot
Re: Interfacing transport layer code
Post by M.Heidemann » Tue 3. Aug 2021, 09:18
To give a fitting recommendation, we would need some infos:
1) Which OS are your currently working on?
2) Which device (Serial-number IPEH-XXXXXX) are you refering to specifically?
driverobot
Post by driverobot » Tue 3. Aug 2021, 10:10
Hello! Thanks for the quick response.
1. I am on windows. But it would be great if things could also work on Ubuntu.
2. IPEH-002025 068815
Post by M.Heidemann » Tue 3. Aug 2021, 10:31
Thank you for your quick reply.
We do not offer any sort of API for the PCAN-LIN,
interacting with the device can be done using serial commands,
the full documentation regarding this can be found here:
https://www.peak-system.com/produktcd/P ... ef_eng.pdf
You could write a software which sends the appropiate commands via serial.
one advantage here is that you could use for example use python, which
would make the application also viable on linux.
With a PLIN-compatible device (PLIN-USB (IPEH-004052) , PCAN-USB Pro FD(IPEH-004061)) you could
also use our PLIN-API, which is available for free:
https://www.peak-system.com/PLIN-API.444.0.html?&L=1
This would enable you to write your own software and have your PLIN
interface act as a LIN-Node (Either as Master or Slave).
We also offer a PLIN-driver for Linux, however it is in BETA currently:
viewforum.php?f=237
The aforementioned PLIN-API and PLIN Linux driver are not compatible with PCAN-LIN(IPEH-002025)
