Transmission rate too slow
Posted: Tue 14. Sep 2021, 14:18
by JulianH
Hey,
we want to create a test bench. The test bench shall simulate the CAN-traffic of an entire car by using a CAN-dump in which the simulated CAN-traffic is received by a microcontroller. Therefore it is important for the microcontroller to receive all CAN frames in the original time intervals. E.g. if the CAN-dump logged ~1500 frames per second, the sender also has to send ~1500 frames per second. Our first approach was to simulate the CAN-traffic using the PCAN-USB x6 in conjunction with Busmaster. However, Busmaster seems to be much too slow (factor 3-4, i.e. only ~500 frames per second).
Is the PCAN-USB x6 even able to transmit frames that fast?
Are my chances for success higher with PCAN-Trace than with Busmaster?
Re: Transmission rate too slow
Posted: Tue 14. Sep 2021, 15:03
by M.Heidemann
you already contacted us via email,
please stick to one method of communication.
-closed-
