PCAN-Router Pro FD CAN Parmas Read Example
Programmable 6-Channel Router for CAN and CAN FD with I/O and Data Logger
maneeshsin01
Post by maneeshsin01 » Fri 24. Sep 2021, 15:52
Which example shows setting up different parameters for reading can data ?
e.g. params like baudrate, databit ,parity ?
CAN_BITRATE_CAN1= f_clock=80000000, nom_brp=1, nom_tseg1=127, nom_tseg2=32, nom_sjw=32, data_brp=1, data_tseg1=7, data_tseg2=2, data_sjw=2
Maneesh
U.Wilhelm
Re: PCAN-Router Pro FD CAN Parmas Read Example
Post by U.Wilhelm » Mon 27. Sep 2021, 10:29
We talk about a CAN Communication - so you have to know what settings your network need and use the can_user.h header file (which is part of all our samples in the ARM Develope rPackage - Router Pro FD Examples)
to setup the correct Bitrate / Timings.
DataBit, Parity :?: ...these are used for RS232 - not for CAN....
