Hello ,
I am using PCAN_USB device to set the GPIO by sending CAN message,
problem is when I am sent message to set particular GPIO , but i am receiving other response ID in-between.
could you please guide me in avoid this problem .
PCAN-USB: Setting GPIO (Labview)
- response received
- 2021-10-25_10h45_47.png (29.97 KiB) Viewed 9070 times
- Block diagram
- 2021-10-25_10h44_23.png (21.96 KiB) Viewed 9070 times
Re: PCAN_USB_
Sorry - this is a problem in your environment / used module. We do not know what exact you are tlaking about (which GPIO, which ID...?!?)
We could not help you! Also we do not support LabView.
Simply try first with PCAN-View and see / check if the System works as you aspect - after that try it in LabView.
