problem in ip link set up can0 Linux
sara_123
Post by sara_123 » Tue 2. Nov 2021, 08:49
Hello again
after a lot of back and forth, I could finally run the interface and now with command
ifconfig can0
I can see
can0: flags=128<NOARP>  mtu 16
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
but when I run the command
ip link set can0 up
I receive the following error message
RTNETLINK answers: Invalid argument
my system is fedora 33
The linus itself has the driver for peak-usb pcan and after installation, as it had problem, I again removed it.
the result of
/proc/pcan
is nothing and it does not produce anything.
after I uninstall the drivers with the followiing command I see status
lsmod | grep ^peak
I see status as
peak_usb
can anyone help me and say why the result of ip link is that?
sara_123
Re: problem in ip link set up can0 Linux
Post by sara_123 » Tue 2. Nov 2021, 09:24
I solved the problem myself by calling this command before the other one
ip link set can0 up type can bitrate 500000 dbitrate 2000000 fd on fd-non-iso on
just a question here, for other CAN, what bitrate shall be set?
Post by M.Maidhof » Tue 2. Nov 2021, 10:43
you should set the bitrate to the value of your CAN nodes with which you will communicate.
BTW: SocketCAN related questions should be asked in the Linux section of our forum, because the PCANBasic API does not work with the SocketCAN driver.
[Moderator: Moved topic to Linux section.]
