PCAN-PCIE adapter and compatibility to PC-Vendors
Posted: Sun 5. Dec 2021, 12:18
by Gabriel6
Hi
We have this card in our possession
https://www.peak-system.com/PCAN-PCI-Ex ... .html?&L=1
we tried connecting it to DELL 7090SFF
https://www.dell.com/en-us/work/shop/de ... 90-desktop
The card does not physically be connected in the chassis
Questions:
1. can you supply computer model that certified to be using this card (preferably from DELL)
2. Alternatively, does the USB adapter from your site offers the same functionality as the PCIE card?
https://www.peak-system.com/PCAN-USB-Pro.200.0.html
would appreciate your prompt response
Gabriel
Re: PCAN-PCIE adapter and compatibility to PC-Vendors
Posted: Mon 6. Dec 2021, 08:45
if your are using a desktop system with small form factors (low profile), our standard PCAN-PCIe cards will not fit. As a workaround you could use our PCI Express Low-Profile Adapter and a miniPCIe CAN card:
https://www.peak-system.com/PCAN-miniPC ... .html?&L=1
https://www.peak-system.com/PCIe-miniPC ... .html?&L=1
You can also use an USB based solution like PCAN-USB or PCAN-USB FD on that system.
Posted: Tue 7. Dec 2021, 13:53
by Gabriel6
Thanks Michael
can you recommended on a unit that is in stock that is compatible with spec and D type pin layout
The unit should also have dual D connector as controller is dual.
Thank you
Gabriel
Posted: Tue 7. Dec 2021, 15:29
please contact our sales team regarding the availability of the products: order[at]peak-system.com
At the moment the availability of products changes in between minutes/hours, so the forum will be not the right place to give you information about that.
All dual channel cards will delivered with two D-Sub CAN connectors, see our website for more details.
Posted: Wed 8. Dec 2021, 15:14
by Gabriel6
thumbs up!
thank you very much for the answer - will contact through our purchasing team
all well
Gabriel
