GUIDE: PCAN-LINUX on Raspbian / Raspberry PI OS
Posted: Wed 2. Feb 2022, 14:29
We have alot of customers that want to use their USB based PCAN-interfaces on a Raspberry PI, specifically
using Raspbian / Raspberry PI OS.
Our Interfaces can either be used as character devices (CharDev) with our proprietary APIs (Such as PCANBasic, CAN2.0 API, CAN FD API) or as network devices (NetDev) using the SocketCAN API.
This guide will outline the necessary steps for both.
PCAN-APIs (CharDev)
Here a small guide which we have tested on a RPI 4 with the 2019-07-10-raspbian-buster.img:
Download the latest raspbian image and install it on a sd card using Win32DiskImager or any other tool
boot your RPI, and setup all necessary settings (language, network etc.)
now update your PI to the latest version and reboot once:
install the kernel headers:
install libpopt-dev:
Now download the peak-linux driver-8.14 (or newer) from our linux website and put it into the /home/pi directory:
Link PCAN-Linux Page:
http://www.peak-system.com/fileadmin/me ... /index.htm
Untar the package:
Change into the extracted PCAN-Linux driver folder:
Clean up the build directory:
Build PCAN-driver as CharDev:
Note: If you use a Raspberry Pi Compute Module and need PCI/PCIe-support, remove the "PCI=NO" option.
Install Driver:
Load the driver:
Show all connected PCAN-USB devices:
You can now use all chardev tools and libs to work with the PCAN-USB devices,
the usage is explained in details in the PCAN-Linux documentation, chaper 4 -"Usage of the Driver"
Link PCAN-Linux Documentation:
SocketCAN (NetDev)
The mainline-kernel drivers for PCAN-Interfaces are included in the latest Raspberry PI OS releases,
we were able to confirm this being the case for the following releases:
Current Raspberry PI OS Releases:
via "ip link", enumerated in ascending order as can0, can1, etc.
For information on how to use the devices, please scroll down to the USAGE ScoketCAN section below:
Older Raspbian / Raspberry PI OS Releases:
Older version of Raspbian /Raspberry PI OS do not include the mainline-kernel drivers
and need additional steps to use your USB-based PCAN-interfaces with SocketCAN:
Untar the package:
Build driver as NetDev:
Install the driver:
Load the driver:
show all connected PCAN-USB as canX devices
You can now proceed with using the devices with SocketCAN as described below:
USAGE SocketCAN
Using "ip link" the devices will be listed as can0, can1 in ascending order:
From there the devices can be set up using the "ip link"-utility and be used with - for example - the can-utils package (which includes cansend, cangen, etc)
In case you want to install the can-utils:
Setting up the device@500kbit/s via "ip link":
You can then proceed to use the device with -for example -candump:
We hope this guide will help you getting started with using your PCAN-USB inteface
on Raspberry PI.
PCAN-APIs (CharDev)
$ sudo apt get update
$ sudo apt get upgrade
$ reboot
$ sudo apt-get install raspberrypi-kernel-headers
$ sudo apt-get install libpopt-dev
Untar the package:
$ tar -xzf peak-linux-driver-8.14.0.tar.gz
$ cd peak-linux-driver-8.14.0
$ make clean
$ make PCC=NO PCI=NO ISA=NO DNG=NO
Install Driver:
$ sudo make install
$ sudo modprobe pcan
$ cat /proc/pcan
SocketCAN (NetDev)
- Raspberry PI OS based on Debian 11 (2022-01-28-raspios-bullseye)
- Raspberry PI OS based on Debain 10 (2022-01-28-raspios-buster) - Legacy
$ reboot
Untar the package:
$ make clean
$ make PCC=NO PCI=NO ISA=NO DNG=NO NET=NETDEV_SUPPORT
Install the driver:
$ sudo make install
$ cat /proc/pcan
USAGE SocketCAN
pi@raspberrypi:~ $ ip link ls
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DORMANT group default qlen 1000
4: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
link/can
pi@raspberrypi:~ sudo apt-get install can-utils
pi@raspberrypi:~ $ sudo ip link set can0 up type can bitrate 500000
pi@raspberrypi:~ $ candump can0
can0 100 [8] 50 43 41 4E 2D 55 53 42
can0 101 [8] 75 73 65 64 20 6F 6E 20
can0 102 [8] 52 61 73 70 69 6F 73 21
on Raspberry PI.
