PCANTP_HANDLE_LANBUS1 always occupied
T.Thomas
Post by T.Thomas » Fri 29. Apr 2022, 09:19
Hi all,
I was just experimenting with the UDS-Api a bit, using the PCANTP_HANDLE_LANBUS1 channel to the Peak Virtual Gateway, connected to and Ethernet Gateway DR FD. Which worked fine for some days, but now suddenly stopped working, as the PCANTP_HANDLE_LANBUS1 channel is always occupied according to the PUDS_PARAMETER_CHANNEL_CONDITION, which causes UDSApi.InitializeFD_2013(cantp_handle.PCANTP_HANDLE_LANBUS1 , ...); to always fail.
As I don't know about any other software that might occupy that channel, I tried to restart the computer, restart the virtual gateway service and even reinstall the PeakOemDrv package, which all didn't help.
Any hint on what might be going on and how to fix it? Thanks for any help!
Greetings
Thomas
Re: PCANTP_HANDLE_LANBUS1 always occupied
Post by PEAK-Support » Fri 29. Apr 2022, 09:51
Check if a other Software like PCAN-View is running next to the Application.
You also could "free" such "in use" Channels (maybe Debugger have left a connection etc.) with the new PEAK-Settings (part of the latest Driver - will be found after driver installation in the Control Panel)
If you still have problems, please connect us at support[at]peak-system.com (we speak Englisch / German )
