Display Rx Messages in Hexadecimal
K1890350
Post by K1890350 » Mon 20. Jun 2022, 10:44
I'm looking into how I can display the raw hex message received from the ECU.
I understand that using Read_2013 would return a status code for the receive queue. But, is there any way I can read and display the raw hexadecimal message from the ECU onto a GUI (and not a status code message?).
NOTE: Communication has been established between transmitter and receiver via mapping.
Best,
K1890350
Re: Display Rx Messages in Hexadecimal
Post by K.Wagner » Mon 20. Jun 2022, 11:40
when the function returns PUDS_STATUS_OK, then you got a message. This is placed in the out_msg_buffer parameter.
When you read a message, this is retrieved in form of a uds_msg structure. This structure hast a field "msg" of type cantp_msg which has a property itself called "msgdata". This gives you access to the generic data bytes of the received message (check the sample project 01_server_response_ecu_reset_USDT):
If you rather want to have the segmented frames that are part of an ISO-TP multiframe communication in your output, then you will need to use the ISO-TP parameter PCANTP_PARAMETER_FRAME_FILTERING, using the value "PCANTP_FRAME_FILTERING_VERBOSE". More informaiton can be read in the PCAN-ISO-TP documentation, chapter 3.5.14
