Problem connecting the 'PLIN-USB': V_Bat error
Posted: Tue 11. Oct 2022, 10:28
I have trouble connecting the 'PLIN-USB'-Interface with my LIN-Bus. If I want to connect the interface to the bus, no connection can be detected. The program itself shows the error 'Hardware: V_Bat missing'.
My setup (see also: attached images):
- Motor (connected to power supply + LIN-Bus)
- PLIN-USB connected via (split) D-Sub-Adapter (Out: D-Sub signal + Banana-Plugs for: LIN, Voltage + (V_Bat), Voltage - (GND))
To check, whether or not the problem lies in splitting the signal from the D-Sub-Plug, I connected the USB-Interface through soldering banana plugs to pin 9 (V_Bat) and pin 5 (GND) of the outgoing D-Sub-Plug. I did measure the voltage at 12V (V_Bat) and 0V (GND) directly at the solder points; still, 'Plin-View-Pro' shows the aforementioned error.
Infos: Firmware Version: 1.2.0 (PLIN-USB)
I'm new to LIN-Bus, so please forgive any 'beginner mistakes'. I hope you can help me out.
Best regards
Simon H.
Best regards
Simon H.
