Linux drivers for Debian (Rock pi)
Posted: Tue 15. Nov 2022, 16:27
i have debian 9 running on Rock Pi.
Linux headers look like:
I get the following output for:
and
From this I assume that there is no need for installing linux drivers.
But, while building PCANBasic library, I get, "Unable to build pcanbasic for Linux: install the pcan driver first":
So, I tried installing drivers. Kernel headers are already installed. While building the driver, I get:
What could I be doing wrong? On raspberry pi had worked seamlessly but seems a bit challenging on Rock pi. Thanks in advance!
Deepak
# uname -a
Linux linaro-alip 4.4.154-90-rockchip-ga14f6502e045
# ls -l /usr/src/
total 3568
drwxr-xr-x 24 root root 4096 Jul 10 2019 linux-headers-4.4.154-88-rockchip-00030-g90239a6
drwxr-xr-x 24 root root 4096 Jul 30 2019 linux-headers-4.4.154-90-rockchip-ga14f6502e045
-rw-r--r-- 1 root root 3642524 Mar 3 2017 xorg-server.tar.xz
$ sudo grep PEAK_ /boot/config-`uname -r`
CONFIG_CAN_PEAK_PCI=m
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_CAN_PEAK_USB=m
$ lsmod | grep ^peak
peak_usb 40960 0
:~/PCAN-Basic_Linux-4.6.2.36/libpcanbasic$ make
*** Processing 'pcanbasic' directory...
make[1]: Entering directory '/home/linaro/PCAN-Basic_Linux-4.6.2.36/libpcanbasic/pcanbasic'
Makefile:70: recipe for target 'all' failed
make[1]: *** [all] Error 1
make[1]: Leaving directory '/home/linaro/PCAN-Basic_Linux-4.6.2.36/libpcanbasic/pcanbasic'
Makefile:54: recipe for target 'all' failed
make: *** [all] Error 2
~/peak-linux-driver-8.15.2$ make PCC=NO PCI=NO ISA=NO DNG=NO
make[1]: Entering directory '/home/linaro/peak-linux-driver-8.15.2/driver'
*** Host OS Release=Debian GNU/Linux v9
*** Host machine kernel version=4.4.154-90-rockchip-ga14f6502e045
*** Driver kernel version=4.4.154-90-rockchip-ga14f6502e045 (4.4.154)
*** Path to kernel sources=/usr/src/linux-headers-4.4.154-90-rockchip-ga14f6502e045
*** use KBUILD=yes
*** use DKMS=
*** gcc version=6.3.0
/bin/sh: 1: cannot create dkms.conf: Permission denied
Makefile:587: recipe for target 'dkms.conf' failed
make[1]: *** [dkms.conf] Error 2
make[1]: Leaving directory '/home/linaro/peak-linux-driver-8.15.2/driver'
Makefile:84: recipe for target 'all' failed
Deepak
