Passing multiple variables across gateway and scaling them
spassen
Post by spassen » Tue 20. Dec 2022, 19:55
Does anyone have an example of how to receive multiple variables on CAN 0, pass them through the gateway to CAN1 and scale the outputs?
I have the config set up and it is passing the variables from CAN 0 to CAN1 correctly, but when I adjust the scaling on the output variable, it doesn't change it.
I am sure I could sort the issue with an example of this specific operation.
Open to other resources as well. I tried working through the tutorial but it is scaling a variable on CAN bus.
Thanks.
Re: Passing multiple variables across gateway and scaling them
Post by PEAK-Support » Wed 21. Dec 2022, 11:26
With the PCAN-Mio Standard Firmware you could use the PPCAN-Editor to create the configuration.
There are many Tutorials available - please check the download Package of the Device.
You also could contact our support[at]peak-system.com, send your PPCAN-Editor Configuration and explain what exact you like to do - we will chek it...
