minipcie can XENOMAI Driver registration failed
ttyyy145
Post by ttyyy145 » Fri 10. Mar 2023, 04:28
The RTDM driver of xenomai will apply for an interrupt number when registering, but the applied interrupt number 16 has been occupied by linux, resulting in the failure to open the device normally。
I turned off the device using idma64.5, this problem has been solved, but is it legal to do so, is there a better solution
S.Grosjean
Re: minipcie can XENOMAI Driver registration failed
Post by S.Grosjean » Fri 10. Mar 2023, 14:35
You should certainly activate the CONFIG_XENO_OPT_SHIRQ=y option in your Linux Xenomai co-kernel configuration so that IRQ16 could be shared by more than one device, or, you could enable usage of MSI in your BIOS so that each device will get its own and private IRQ line.
[Update]
If present, "noapic" kernel command line option must be removed.
— Stéphane
