read message segment
Posted: Thu 23. Mar 2023, 13:27
by clem69
I notice that when I receive an iso tp message with more than 8 bytes of data,
the function UDS_read_2013() first sends a message which allows us to prevent that we are going to receive a segmented message and then we receive the complete message.
can we delete the message that prevents the frame to segment.
thank you
Re: read message segment
Posted: Thu 23. Mar 2023, 13:45
by clem69
for instance :
normally I have to receive 2 frames but I receive 4
0x88 CA CA CA 00 00 00 00 00
0x88 00 00 00 00 00 00 00 00
0x88 B2 B0 B1 00 00 00 00 00
I want to receive only the last two frames
Posted: Thu 23. Mar 2023, 15:08
by K.Wagner
not sure to understand. Please post some code of what you are trying to do in order to better help.
If I understand well, you are sending an UDS request (UDS_Write_2013 ?) and receiving the corresponding confirmation and response. This is the way the protocol works. The confirmation cannot be avoided. If you use the function UDS_WaitForSingleMessage_2013 for dealin with the UDS data, then you can read the confirmation first and discard it, as this function has a parameter (boolean) for this.
result = UDS_WaitForSingleMessage_2013(PCANTP_HANDLE_USBBUS1, &request, true, 10,
100, &confirmation);
result = UDS_WaitForSingleMessage_2013(PCANTP_HANDLE_USBBUS1, &request, false, 10,
100, &response);
